Question about Kitchen Ranges
Jenn Air radiant cooktop - model JED 8430BDB, #14249046 Control knob light stays lite when turned off.
Some lights stay on until the burners cool down completely. This is a safety feature.
Posted on Jul 08, 2008
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn-Air radiant cooktop, two of the burners run on high no matter where the control knob is set?
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 03, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn Air JED 8230 cooktop with a bad heating element
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 28, 2010 | Jenn-Air JED8230 Electric Cooktop
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
JED 8320 fan and burner switch
http://www.whirlpoolparts.ca/index.php?PHPSESSID=f2330dc59be8bdd5f5463d5e0d1362f9
Oct 05, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
Oct 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
102 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
