Question about Sharp AL 1631 Copier
My Triumph Professional Care 9000 toothbrush won't shut off...
It's acting possessed. It simply won't turn off. Last night I couldn't get it to turn on, and now it won't turn off--and it's fully charged. It's been going for 20 + minutes. It's doing this completely out of the blue. Two days ago it worked perfectly. THanks
  • jackieteh Mar 04, 2009
    my braun oral b triumph professional care 9000won;t turn on
  • Sharp Master
  • 2,794 Answers
Try another outlet and see if it works the same. If it still continues you shold have a technician look at it.
Posted on Jul 10, 2008
I have a 2001 Mazda tribute ...last night my bf borrowed my car ... Shut the vehicle off left for a few hrs.. When he came back the car wouldn't turn over it's like the wheel is locked...and it...
Wiggle steering wheel back and forth to see if will allow the key to turn. If not then you can just call me while hes stuck out of town. Ill take care of you dear. hehe
Aug 02, 2013 | Cars & Trucks
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Feb 04, 2013 | Health & Beauty
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
3756 f 136 manual
The User Manual for the Braun Professional Care 500 Electric Recharegable Toothbrush can be found line here:
http://www.service.braun.com/line/OC/O3756/O3756_14_MN.pdf
Should this be helpful, please rate my assistance.
Thank you!
Jan 09, 2012 | Oral B Braun B Professional Care 500...
I have purchased a Braun proffessional care electric toothbrush and cannot charge it. I have tried three different plug adapters. I have changed the toothbrush at Boots 3 times. I have tried to charge it...
Your electrical socket may be wrongly wired, with polarity mixed up. Try another socket. Also, some electric toothbrushes need to be "off" to successfully charge. Maybe the flasing red light for 10 seconds is telling you the toothbrush is "on" and not accepting charge.
Sep 12, 2017 | Oral B Braun B Professional Care 500...
My Braun electric toothbrush suddenly started by itself a couple of nights ago; it continued to turn itself on when I pressed the button to stop it, and finally stopped when I put it in the charger which...
A. the stopping when in charger is normal. (have one myself)
B. the sudden starting could be signs of a short-circuit (possibly caused by electronic metal-fatigue)
Jul 20, 2011 | Oral B Braun B Professional Care 500...
Braun Oral-B Triumph Professional Toothbrush won't shut off...
I think I may have just found issue with the problem, and that is that the inside of the unit has got wet. I suggest taking the casing off of the tooth brush and let it completely dry out, then test the unit. Hopefully this will fix your problem
Jul 07, 2008 | Norelco Cool Skin 7775X Electric Shaver
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Sharp AL 1631 Copier Logo
511 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
