Question about Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout ....
Moen 87780 handle works but is loose. Not a problem yet, but want to prevent one. How to remove the handle without damaging the finish?
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 659 Answers
SOURCE: Moen One-Handle Kitchen Faucet Leak - Hot Only
http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
Posted on Apr 11, 2009
SOURCE: Loose handle on my Moen single handle kitchen faucet
I had a similar problem. After a few weeks the lever began to "tighten up". It began first with the hot water at full flow and progressed over a couple of weeks to full control.
Posted on Oct 28, 2010
  • 92 Answers
SOURCE: Replacing Moen 1225 cartridge.
you will need a puller more then likely but what you can try is a little wd-40 lubricating spray
Posted on Feb 05, 2009
I have a Moen Ascent kitchen faucet. The chrome handle that is attached somehow to the control valve underneath has come loose. How is the handle attached to the valve and what is the remedy?
Moen kitchen faucet handles in this series are held onto the cartridge stem with a set screw. First turn off the water supply to the faucet. You need to move the handle until you can see the small plug button that covers the set screw. This is ~3/4" from the edge of the handle. Remove the plug with a small screwdriver or other levering tool and adjust the handle if needed to get it on the cartridge stem. Then find the appropriate Allen wrench to tighten the screw. (It may be a 3/32" but this isn't always true.) To test if you have it tight, turn on the water and see if the water is easy to turn on and off. Turn off the water and replace the plug button. Then turn the water one last time.
To see a parts diagram for a couple of models of Ascent faucets, see https://www.moen.com/support/Ascent/Ascent_Chrome_onehandle_high_arc_pulldown_kitchen_faucet/S71708 or https://www.moen.com/support/Ascent/Ascent_Classic_stainless_onehandle_high_arc_pullout_kitchen_faucet/S71709CSL .
I hope this helps.
(Do not over-tighten the set screw. This could damage the cartridge or handle.)
Mar 04, 2017 | Moen Plumbing
Can't remove the collar without damage to finish. on moen 7385
They best way to remove the collar is lube it up I have found that WD-40 works very well but have been also told that OFF the bug spray in the Orange can works as well, after it has set for about 20 min then a strap wrench should be used.
Feb 12, 2015 | Moen Plumbing
I need to change the 1255 cartridge on a Moen Benton Faucet.
Usually they unscrew. Sometimes if the faucetis in a hardwater zone the mineral deposits build up and make getting the dome off very hard. Use a strap wrench to get a little more grip, this will prevent damage to the finish and allow you to twist harder.
Dec 27, 2013 | Moen Benton High Arc Kitchen Faucet with...
Leaking CA87681 moen kitchen faucet
Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
My handle is loose but I cannot find a tool that will fit the set screw. What is it, what size. Blade screw, Phillips Screw, Hex, torx, what? Moen T2442 single handle shower diverter.
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Aug 07, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
How to remove the handle of a monticello 4551 moen faucet. I need to access the cartridge. After screwing the brass stem out, does the chrome ell shaped cap rotate to unscrew or is there a set screw I...
grab bottom of handle,(the fat part of handle closes to faucet body) and grip hard and turn counter clockwise to get to cartridge. dont use channel locks pliers or you risk damage to finish. can be done by hand and very tight grip
Jun 23, 2009 | Moen 4551___ Monticello Popular Two Handle...
Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Logo
213 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
