Mobile will not let me receive or send text messages
Please help I have been trying to get in touch with someone to help me to solve my problem, I can`t send or recieved text messages it keeps saying operation failed what can I do please Jacqui
Re: mobile will not let me receive or send text messages
Try ringing your network and ask someone at customer-services, you will be put onto a computer first then go through the options and see if it can help and if it can great! or if it can't and it fails it will direct you to a real human being!
LifehackerJul 15, 2011 - Cell phones and smartphones will differ in the menu options and buttons, but in general, the process of sending a text message to someone else's phone is pretty straightforward. From your phone's main menu find the "Messages" or "Messaging" option or application. Then select "Text Message" or "Text Messaging."
WISC?TVFeb 28, 2009 - Go to phone's main "Menu" and select "Messaging" option. 2. Select "Text Messages" (some might see "Send SMS") and then select "Write message." 3
for sending text messages : 1.go to your message settings and check the message center number to see if it is correct 2. call to your network operator customer care 3. request the message center number... 4.note it down 5. go to message settings>message center number 6. insert the number which is noted by you and save it
my mytouch can received txt msgs but I can't send messages because an icon appears with an envolope with an explanation mark! meaning "txt not sent"... Help how can I solve this problem
I had the same problem and came to this site for help but the solutions didn't solve the problem of "cannot send text message" on htc touch hd. All service numbers correct. Went to START/SETTINGS/CONNECTIONS/ADVANCED NETWORK/SMS SERVICE then changed from "gprs" to "gprs preferred". Double checked and had reverted to "GSM" but sms now works - finally!!! Hope this helps.
firstly contact your operator and request for sending you the mms activation settings once you receive them as a message save them on the phone now you are ready to send and receive MMS messages
now to the part of sending an MMS
go to messages click on the
menu then New then MMS
now key in the addresse in the TO part and in the msg body
go to select insert Picture/ Video to insert a picture or video from your gallery
similarly if you want to add text select the text
also the same for audio
you can select all or any of the picture/ text/ audio and send as an MMS
hope this helped
cheers
PS: if this has been of any help pls rate the solution
Well for the past week or so, Sidekick has been having problems with receiving text messages from other service providers such as AT&T and Sprint. It is best that you call up customer service to find a solution.
To fix this problem is you need to borrow/own a phone that is from
your service provider that isn't touch or 3G phone. I used Nokia 5200
or Nokia 5300.. Same phones
Change the number for Voice mail. (Your Cellphone Number) then put your Voice Mail # on your Text number where you receive your Text service SMS. Make sure both # has the +1 at the start.
hello there.... well it seems that the problem is with network you need to be with the network that solves your problem that is T-mobile...
get a T-mobile connection and transfer your mobile number to t-mobile...as AT&T tech support could not solve your problem its time to move ....you have tried every possible move yourself just go for better customer focused company
