Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
How do I find my application quick launch bar? Model #prd07t10wwh7 I have not been able to get it working.
How do i find my application quick launch bar
Posted on Feb 05, 2011
Hpp dv6 1115ee quick luanch notwotking
This model doesn't officially have Windows 8 support. That would be why the quick launch doesn't work. Also quick launch I believe for HP is only supported for Win 8 Pro and Enterprise versions, not the consumer version.
Jun 08, 2013 | HP Pavilion Computers & Internet
Tip
Get back the Quick Launch bar Windows 7's new taskbar functions as a program...
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it:
1. Right-click the taskbar and choose Toolbars --> New Toolbar.
2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area.
It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title.
Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar.
You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
on Jan 12, 2010 | Computers & Internet
How to put program type on tool bar
  1. Adding Icons to the Task Bar
    1. Click on the Start Menu to open it
    2. Click on "Programs" and find the program for which you want to create an icon
    3. Move your mouse pointer to the program you want to use
    4. Depress and hold down the right mouse button while you drag the icon to the Quick Launch toolbar section of the Task Bar
    5. When you release the right mouse button, a short menu will appear
    6. Choose "Create Shortcut(s) Here." An icon will be created in the Quick Launch toolbar on the Taskbar
  2. Deleting Icons from the Task Bar
    1. Move the mouse pointer to the icon you want to delete
    2. Right-click on the icon
    3. Choose "Delete" from the short menu that appears. The icon has been deleted, but the program is still available to you on your hard disk
    NOTE: If you have carefully followed the steps above to add the icon to your Quick Launch toolbar, deleting it will NOT delete the program from your computer, it will simply remove the icon from your toolbar. The program will still be available to you.
Also you can "Drag" the program, to the bar, and "Drop" it on it. Check out a freeware application called StartupCPL at http://www.mlin.net/StartupCPL.shtml. This places a Startup icon in your Control Panel which, when opened, lists all applications on your PC with a check box for each one. Simply put a check mark in each application you want to open minimized on startup. By the way, it states it is for Windows ME and 2000, but I have had it on XP for quite a while and it works fine.
Mar 01, 2010 | HP Pavilion dv6000z Notebook
The geen volume bar is permanently on my desktop and I need to hide it. Can you tell me how to do it please?
Hi, thsi issue normally appears when the HP Quick launch buttons driver is corrupted. Uninstall and reinstall the HP Quick launch buttons driver.
You can find the HP Quick launch button driver in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3355661&taskId=135&prodTypeId=321957&prodSeriesId=3355650&lang=en&cc=us
or
http://search.hp.com/query.html?cc=us&lang=en&charset=utf-8&qt=HP+Compaq+6510b&la=en
Select your operating system and download HP Quick launch buttons driver sn install.
You can disable the green volume bar by perfomring the following steps:
1. Hold the windows key and press 'R' -> Type msconfig -> Click Ok
2. Select the StartUp Tab in the System Configuration menu.
3. Remove the Checkmark from the HP Quicktouch On Screen Display item.
4. Click on OK and Restart if required.
Please do let me know if the above steps worked for you.
Dec 30, 2009 | HP Compaq 6510b Notebook
I have just reinstalled windows and my volume control center is not in my quick launch bar , how do i get this back
The Volume Control Center is next to the clock, not the quick launch bar. if you do not have it, then check to see if you sound drivers are loaded.. verify that by going to the control panel and then sound properties.. if not, then install them, put check mark in box to show volumne control, if that don't work, then take check mark off and then put on...
Sep 05, 2009 | Labtec LCS 2424 Computer Speakers
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Cannot play sound on my computer
take a look at your quick launch tool bar (the little arrow nex to the clock.) run your pointer over each one of them and see if any of the audio device is running. if so, right click on theicon and exit or close.
please rate the answer if that solved your problem
thank you
Oct 16, 2008 | Computers & Internet
I opened a yahoo mail account yesterday and would like to put the yahoo mail icon on my quick launch bar at work. How do I do that? Yahoo has no "contact us", only FAQS. Shari Potter
two ways..open the yahoo..and grab the icon in the browser window, and drag it to the quick launch..other way is to right click on that panel, and customize that panel, by adding the application
Oct 09, 2008 | Computers & Internet
Icons and start lost
If you're looking for the quick launch icons on the task bar, right click on the task bar, click properties, then check the box that reads show quick launch, apply, and they should return.
Jun 12, 2008 | Toshiba Satellite A100-S8111TD Notebook
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
83 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
