Question about Magic Star Karaoke Microphone
Microphone makes a static sound when it gets moved. The static comes through the speakers when the microphone is held in different positions. Could it be the cord or the connection to the mic?
  • 30 Answers
Make sure your connections are clean and tight. There may also be an intermittant or broken wire in the cord. See if you can narrow the problem down by holding some parts of the wire stationary and moving other areas. gently shake the mike with the set off and listen closely for loose parts making noise. (The idea is to eliminate the areas that are good and what's left is broken.) Hope this helps
Posted on Dec 29, 2010
Crackling static in sound
reduce the volume of the microphone
Mar 25, 2014 | HP ProBook 5310m (FM997UT) PC Notebook
Can't tell where positive and negative are
a simple aa battery and a couple pieces of wire is all you need,connect wires to the speaker and then by attaching the wires to the end of the battery you can make the speaker move. when the speaker moves out follow the wires just as they are on the battery . the positive side of the battery will be the positive to the speaker. hope this helps.
Apr 05, 2013 | Car Audio & Video
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Static electricity shorted as I went to turn my speakers off. now I have no sound, but the power light comes on.
click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Feb 14, 2012 | Audio Players & Recorders
Static electricity shock blew a circuit for the speakers. The power light is on, but no sound.
hope this helps
Feb 13, 2012 | Altec Lansing ACS 45.1 Computer Speakers
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
Basically we are getting a static sound every now and again. I think it has to do with the wireless signal because it only happens when the room is filled with people not when the room is empty. How can...
Try moving belt pack around on person (speaker) and try moving receiver closer to person speaking, also keep receiver elevated, off floors and antennas need to be up. Wireless signal is like "line of sight" and if there's a ton of obstructions you're cutting signal strength. Also make sure you ALWAYS use fresh batteries, weak batteries will do the same.
Feb 25, 2011 | Sennheiser MKE105S LAV MIC w/PIGTAILS -...
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Sound card dell xps400
I don't think many people have a trouble free web cam, whatever make or model of pc or web cam. I get echo and feed back; if that's wot you mean by static, or do you litterly mean static. Helps to have your volume down a touch and the person who you are speaking to also, especially if it has a built in microphone(sorry, not checked your model), a seperate microphone is best as it's away from any possible speaker feedback from your pc's speakers, or any other clse electrical interference. Hope this relieves it a little.
Oct 16, 2006 | Logitech QuickCam Communicate STX Personal...
Magic Star Karaoke Microphone Logo
291 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
