KLH Model 09 speakers
The plus (+) clip in back of the speaker broke off and therefore the plus wire cannot be held in place; therefor I do not get any sound through the speaker. How do I resolve this issue?
  • 682 Answers
Speaker terminal is present in radio shack if you have technical background you can replace it easy otherwise you pass it to service technician.
Posted on Jul 08, 2008
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
One of the clips on the back of my klh-HT-9930 speakers that holds the speaker wire in place broke off. Is there a way I can fix it or get a replacement part?
you can find replacements from radio shack or maplins. you may like to try a stronger type as the ones shown tend to be a little weak
Apr 10, 2011 | KLH HT-9930 System
What are the correct speaker connectors for this unit RCA, Phono ,3.5 mm ?
Does it have a speaker output - I'm sure it does? More likely it's the 3.5mm. which may look like for headphones. The RCA are for low level signals so therefore it's not for the speakers. Do the speakers have two wires a piece? If they are, then there should be speaker output clips on the stereo to connect to. If they look like phono plugs then they go into the speaker output jacks.
Oct 25, 2010 | GPX S7799 Shelf System
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
KLH RS100 Receiver
Swap the left and right speakers, if the problem transfers, then the left channel is out. Theres 5 amplifier sections in this receiver and that one would be defective. A component troubleshooting technician would need to fix it.
May 10, 2008 | KLH R5100 Receiver
Infinity car speaker
It's very possible the speakers have dual voice coils, therefore, would have two "+" and two "-" connections. With the model numbers of the speakers, I can confirm that for you.
Mar 30, 2008 | Car Audio & Video
Surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Sep 04, 2007 | KLH R5100 Receiver
Detached cube speaker
I had the same problem.
Step one: pop of the grille with a screwdriver or knife inserted from the bottom so that any marks will be hidden when you get the two halves back together.
Step two: If the speaker is held in by screws, you are lucky. Just unscrew the speaker and remove it. If the speaker isn't held into the case by screws, it is a newer model that is glued to the back cover / box. You can separate the glue with a bread knife or thin screwdriver (I used a paint scraper and thin screwdriver). Be careful to work around all four sides. Also, there is a small (about 1/4" long) plastic bump in the center of each of the four sides that clips into a matching groove in the speaker, so you will have to spring apart at least two adjacent sides at the same time to release the speaker from the cover easily.
Step 3: Once you have the speaker out, remove the acoustic sponge, and sit the bottom half on a solid table. Make sure the rubber gasket between the speakers is seated properly and note the position of the 3 notches in the hole of the bottom speaker cover. Place the top speaker cover in place and insert the white plastic 3 pronged clip though the the hole so that the prongs match the notches. Press down hard with two thumbs and it should snap into place.
Step 4: Replace the sponge and push the top speaker back into the cover. Replace the screws if you had them. Otherwise you can glue it again but the clips are quite solid if not damaged by the removal so you can save some effort the next time it happens by leaving it unglued, and just snapping the speaker into place.
Step 5: push the grille back on.
Mar 26, 2006 | Bose Acoustimass 15 System
419 people viewed this question
 Grubhead
Grubhead
