Question about Empire MV-120 Wall Mounted Panel Heater
I have a Empire Wall Mounted Heater that sounds like it is going to blow out flames and blow up and the pilot lite wont stay lit.
SOURCE: Empire Wall Heater(propane) won't stay lit
John Mac here...the solution was that we had shut the pilot off for the summer, and birds had made a nest inside the heat exchanger...coming in through the direct vent. Cleaned out the nest, and it works perfectly. My technician recommends that I leave the pilot buring through the summer to prevent this in the future.
Posted on Aug 30, 2007
  • 70 Answers
SOURCE: Pilot won't stay lit on
I would check the flue out side first to make sure it is not blocked. If flue looks good i would try cleaning or replace thermalcoupl. Most of the dyna glo heater i have worked on have a thermal pile instead of thermalcoupl. If you have a thermal pile then i would lite pilot and hold knob down for about 3-5 minutes before you turn gas valve knob to on. If that doesnt work let me no and i can give you somemore ideas. I hope you get it working. What is the tempature out side?
Posted on Jan 18, 2009
SOURCE: blue flame heater pilot wont stay lit
the thermocouple is bad.replace it and your good to go.about 8 or 10 bucks at your local hardware
Posted on Feb 03, 2009
co7196
  • 3433 Answers
SOURCE: Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Posted on Oct 07, 2009
  • 79 Answers
SOURCE: empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Posted on Nov 29, 2009
Can't light pilot due to breeze coming out of unplugged gas wall heater
It sounds like you have a direct vent heater so you have to take off a pilot access cover to light the pilot. So what happens is the draft coming out of the cover is blowing out the match before you get it in the hole. The trick is to get the match or lighter in the hole quickly as possible so the pressure inside the heater will equalize and the match will stay lit. Then you should be able to lite it. Get it inside the hole fast and it will work. Don't forget to put the cover back over the pilot access or the draft may cause the pilot to go back out.
Feb 10, 2018 | Empire Heating & Cooling
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Jan 30, 2015 | Empire Heating & Cooling
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
Pilot wont stay lit and weak flame
Tap pilot head to knock off any built up corrosion and rust and flame will get better and keep pilot lit
Nov 25, 2010 | Empire DV-35 Heater
Glo warm wall heater will not stay lit
Hi Cindy,
It seems that your heater is not sensing the flame is lit and is shutting gas supply off. There should be what is called a flame sensor, it is a thin pc. of metal that sticks out into where the flame when lit.
This usually gets charred and dirty, if you unscrew it and clean it with a soft cloth then re-insert it, it will get you by. You should get a new sensor when you have a chance.
Good luck and be sure to disconnect from any power source or turn unit completely off when orking on it.
Thanks,
Paul
Jan 27, 2009 | Desa International GWP20T GLOWARM Wall...
Pilot flickers replkaced ther-cup now pilot wont lite/stay lit.
Blow out the dust from the pilot and reposition the pilot where the flame hits the tip. more
Jan 26, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light does not reach thermocouple
the pilot oriface is blocked it needs cleaning out ,
Jan 13, 2009 | Empire GWT-25 Wall Mounted Panel Heater
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
24 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
