Question about Robitussin Cool Moisture 1 Gal. Humidifier
The machine blows out air, but does not use any water.
Humidifier blows cool air only not collecting water
a humidifier doesnt collect water only disperses it. a dehumidifier collects water
Jul 05, 2017 | Humidifiers
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Unit blows air but doesn't dispence water
If you know you are getting water to the water valve, check the out put tube that goes into the humidifier, in the end of the tube that attaches to the valve the is a metering fitting that has just a pin hole opening to restrict the water flow, it is probably clogged.
Jan 26, 2010 | Aprilaire 700 Humidifier
Water not coming through the system. Checked
Have the water line checked for clogged up lines? Blow
air on one side, see if it comes through the other side,
using an air compressor. Hope this will help you.
Jan 04, 2010 | Humidifiers
Not working correctly
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
No moisture
Is the level of water dropping? If so, the humidifier is working. If you have a cool air humidifier you won't see any steam or anything at all. You will just feel cool air. Watch the water level and see what happens.
Good Luck.
Feb 23, 2008 | Hunter 33201 Humidifier
It could be a problem with the water level sensor. It may have gotten stuck, and is unable to correctly sense the amount of water. I just posted the instructions from the manual here.
Nov 05, 2007 | Crane Penguin 1 Gallon Humidifier
Robitussin Cool Moisture 1 Gal. Humidifier Logo
37 people viewed this question
Top Robitussin Humidifiers Experts
Mack Baxter
Dennis
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
