Question about D-Link DIR-600 Router
I have DIR-600 Wireless 150 router , I forgot the username + password when i tried to access configuration page from the web browser. Is there any other way to get to the configuration page. ?
  • D-Link Master
  • 4,338 Answers
reset the router, then go to 192.168.0.1, Username is admin, password is left blank:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 29, 2010
  • D-Link Master
  • 32,281 Answers
You can reset the D-Link back to the default settings by-
Turn off the router, press and hold the RESET button at the back of the router and power up the router. Release the RESET button AFTER 5 secs. or until the LEDs flash.
Open a browser and enter the configuration URL
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
I can login but I have forgotten my password
If you can login, either your browser has stored the login settings or the DIR-600 still has the default settings. Change them to something more secure!
Here are the default settings for the D-Link DIR-600:
USERNAME admin
PASSWORD (none)
IP ADDRESS 192.168.0.1
Link UK DIR 600 Wireless 150 Home Router
Feb 24, 2014 | D-Link DIR-600 Router
How to change passsword in router
TRY TO ACCESS THE ROUTER PAGE BY 192.168.1.1 IN THE ADDRESS BAR OF UR BROWSER. BY DEFAULT THE ROUTER USERNAME IS admin AND PASSWORD WILL ALSO BE admin. IF YOU WANT TO CHANGE THESE THEN GO TO MANAGEMENT PAGE ON ROUTER'S GUI. THEN ACCESS CONTROL PAGE, U WILL SEE PASSWORD SUBTITLE, CHANGE IT THERE AND SAVE THE CHANGES.
IF YOU WANT TO CHANGE THE WIRELESS PASSWORD OF THE ROUTER.THEN GO THE WIRELESS TAB, THEN SECURITY SUB TAB AND MAKE THE CHANGES OVER THERE. SAVE THE SETTINGS AFTER THAT.
Dec 23, 2012 | D-Link DIR-600 Router
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
How to change password?
If you can't remember your Network Password, you need to reset your router in order to change your network password. Here's how to do it;
1. With the router still on, find a small hole in the middle right (router's back is facing you) of the router, near the power chord with label 'reset' below it. Using a thin and hard object like toothpick or wire, press the unseen button inside the hole and hold it for at least 15 seconds.
2. Using a computer connected to the router, log-in to Router's IP which 192.168.0.1.
3. In the log-in page, type 'admin' as username and in most DIR 600 routers, password is usually left blank. If blank password fails, use 'admin' as password.
4. When you get into the Router's page, look for the option "Wireless Setup" and start configuring your wireless access. You may have two (2) options to configure your wireless. The first is by using a wizard, and the second is by manually configuring it. Find your comfort there...
Hope this helps...
Jun 03, 2011 | D-Link DIR-600 Router
Web-based Configuration?
If you're connected to the router, navigate to http://192.168.0.1/ . If you're trying to configure the router remotely, that's a lot more difficult. You'll have to check your manual for more information on that. (Or I can scour through the manual for you.)
Mar 01, 2011 | D-Link Wireless N 150 Home Router 4Port...
How do I change the name from D-Link to our personal name please?
Log into the router and change the SSID or wireless network name Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue. Go to the setup tab and it's there under configuration seesection 3 of the manual
Here is the manual
ftp://ftp.dlink.co.uk/dir_products/dir-615/DIR-615_Manual.pdf
please vote ta
Feb 03, 2011 | D-Link DIR-615 Wireless Router
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | D-Link DIR-600 Router
What is the default login and password for d-link dir 615 router
Open your browser, enter the IP address of your router (192.168.0.1) and click OK. • Enter your username (admin) and password (blank by default). Click OK to enter the web configuration page for the device.
Aug 11, 2010 | D-Link DIR-615 Wireless Router
Can't configure dir-600 after enabling access point only
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.2.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
If you are still not able to access it with above ip then press RESET button for 10 seconds it is in back side of router.Then you can access it with 1 of the above ip.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Problem with my wireless router.
To do that, you must first configure your router. Type in your browser the ip of your gateway. To get your gateway ip, type in your command prompt "ipconfig". Once type, you will be prompted with a username and a password. If you used this for the first time, the username and password are the default of your router. Once you are in, there is a menu there that you can configure to put in your wireless password. Choose WPA, it is much stronger password type.
Jun 16, 2009 | D-Link AirPlus G DSL-G604T (790069265662)...
D-Link DIR-600 Router Logo
569 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
