Question about HP Computers & Internet
An OSD message appears in a box that covers much of the monitor screen. The mouse pointer disappears behind the box whenever I try to sweep into it. The box will not go away (except intermittantly) unless I physically turn off the monitor. It reappears a minute or less later after the monitor has been turned back on.
  • HP Master
  • 32,281 Answers
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Posted on Dec 29, 2010
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
OSD locked. Can't get mouse to work on monitor
-Press and hold the MENU button (on the monitor) for several seconds.
-The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear
Nov 24, 2010 | LG Computers & Internet
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
Apr 12, 2010 | Philips 190B6CB/27 19" LCD
Unwantred announcments in the center of the screen
This problem comes from the control switches on the front panel. I had the same problem and fixed it by opening the monitor (unscrew 3 screws on the back side, remove plastic shape of the stand, unscrew 5 screws of the stand and open the back; unscrew the 2 screws of the button switch panel). Now inject contact spray on every switch button. If the problem remains you may have to replace the button swithces. Thats all!
Oct 12, 2009 | Philips 190V6FB 19" LCD Monitor
OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
Computers & Internet Logo
742 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
