My laptop will not charge!! the charger works, but it just wont charge my laptop!
  • 39 Answers
Most likely either a bad connector on the power cord or you've broken the motherboard connector. check the power cord with a volt meeter. if it comes up fine the i would recommend either contacting the manufacture or taking it to a reputable tech. if you are comfortable with doing it you can take the laptop apart and look at the connector with the laptop apart plug it in (CAREFULL IT COULD KILL YOU) and test the voltage after the connector wit the volt meeter. if it has power then most likely *********** board is dead. if it doesn't have power then you need to repair/replace the power connector.
Posted on Jul 07, 2008
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop wont charge so i brought a new charger but it still wont work.
It could be the battery... they tend to wear out over time. If you run the laptop with the charger plugged in, it works fine, right? It just won't hold the charge?
Aug 31, 2010 | HP Compaq Presario CQ61420us Notebook
The laptop wont charge
Just because the light comes on does not mean the charger is charging. You will have to use a meter and check the actual output of the charger. The problem could be the charger , charger plug, cables or battery. Start the checks with the plugs and cables and go from there. The light can come on but no power going out to the battery.
Oct 12, 2009 | Toshiba Satellite A55-S1063 Notebook
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
Nov 07, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
