Question about Linksys Wireless-G WRT54G Router
Unable to get NOOK to work with Linksys WRT54GS
  • Linksys Master
  • 4,338 Answers
To log into your WRT54G, open a Web browser on a computer that's connected to your router and go to http://192.168.1.1/ - the default username is admin and the default password is blank (leave the field empty).
In the Setup tab, Basic Setup subtab:
DHCP Server should be set to Enable.
If you had to change this setting, be sure to click the Save Settings button.
In the Wireless tab, Basic Wireless Settings subtab:
The first data item is Wireless Network Mode. For reasonable performance, this should be set to either Mixed or G-Only. You should be able to connect your NOOK even if it's set to B-Only, but that would be a very unusual setting and would give slower networking.
Wireless Network Name (SSID) is the name of your Wi-Fi network. If it still says 'linksys', change it to something different-but be aware that you'll need to reconnect all of your current Wi-Fi devices using the new SSID. That's a pain in the behind, but using the default SSID will cause you lots of connection grief if someone else installs a Wi-Fi router with the default SSID, because your devices won't be able to tell them apart. Write down your SSID, being careful to distinguish capital letters from small letters, so you'll know what it is.
Wireless SSID Broadcast should be set to Enable. Otherwise, your NOOK won't see your network. You could type in your SSID, but that's a pain in the behind that you don't need. There's no reason not to enable SSID broadcast.
If you had to make any changes to these settings, be sure to click the Save Settings button.
In the Wireless tab, Wireless Security subtab:
Security Mode: write down which of the choices is selected:
  • Disable
  • WPA Pre-Shared Key
  • WPA RADIUS
  • RADIUS
  • WEP
I say to write this down just in case you run into more trouble and need to ask someone for help.
If 'Disable' is selected: you have no security on your Wi-Fi. Anyone can use your Internet connection, and anyone can listen in if they're in range. If you send unencrypted passwords, email, etc., they could see what you send. Most public Wi-Fi systems (McDonald's, Starbucks, B&N, etc.) have no security.
If either 'RADIUS' choice is selected: these settings are used for large organizations with stringent security requirements and a dedicated authentication server. Your NOOK cannot connect if either of these settings is used. You almost certainly don't want to be using either of these for a home system.
If the 'WPA Pre-Shared Key' choice is selected: WPA offers good security for Wi-Fi and is the best of these choices for home use.
  • WPA Algorithms should be set to TKIP. This is the normal setting for WPA. I don't know if your NOOK will connect if you set it to AES, which is normally used with WPA2 rather than WPA.
  • WPA Shared Key is the access key for your network. Write it down, being careful to distinguish capital letters and small letters. You'll definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. Don't change this unless you're prepared to go back and reconnect your other Wi-Fi devices. Unfortunately, there are some punctuation marks that you can't enter on the NOOK keyboard, and if your WPA passphrase contains one of those you may need to change the passphrase in order to connect your NOOK.
If 'WEP' is selected: the WEP security system is a weak system, easily cracked by knowledgeable hackers. However, many older wireless devices and some of the cheapest new wireless devices can't handle anything better than WEP. This isn't a good situation, but you work with what you've got.
  • Default Transmit Key should be set to 1.
  • Passphrase is not important. It is not your network's access key. Ignore it.
  • Key 1 is the access key for your network. Write it down. It will be either 10 or 26 characters, containing only the numbers 0-9 and the letters A-F. You will definitely need this key in order to connect your NOOK or any other Wi-Fi device to your router. There's no reason to change this, and if you do change it you'll have to go back and reconnect your other Wi-Fi devices.
If you had to make any changes to these settings, be sure to click the Save Settings button. Any changes in this section will also require that your existing Wi-Fi devices be reconnected.
In the Wireless tab, Wireless MAC Filter subtab:
  • Wireless MAC Filter should be set to Disable. If it's enabled and set to Permit only mode, only the devices listed on the MAC Filter List can use your Wi-Fi. If your NOOK isn't in the list, you can't connect your NOOK. Bad ju-ju, huh?
If you had to change this setting, be sure to click the Save Settings button. Changing this should not require your current Wi-Fi devices to reconnect.
It's possible to add your NOOK to the MAC Filtering list and then turn MAC Filtering back on. But that's beyond the scope of this posting. I will, however, mention that your NOOK's MAC address is listed in its Settings screen-on page 2 if it's a NOOK 3G.
In the Wireless tab, Advanced Wireless Settings subtab:
  • Authentication Type should be set to Auto. Do not set it to 'Shared Key'; this won't work with NOOK. Auto should work with any WEP-capable devices. If it's set to 'Shared Key', change it to 'Auto'-this shouldn't affect any of your current Wi-Fi devices.
You should now be able to connect your NOOK using the SSID and the access key that you wrote down.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 29, 2010
  • chills32 Jul 28, 2011
    I had the same problem, linksys wrt54g would not connect the nook color. I tried all the forums and all the setitngs.
    Mine worked with WPA personal, TKIP.
    The trick was......go to linksys.com and download the latest FW for your router. You have to install the FW and then you are good to go. All of a sudden the nook color was seen on the router and all is well.
    remember router ip is 192.168.1.1
2 Suggested Answers
LASITHA-VEGA
  • 428 Answers
SOURCE: NOOK is not capable of responding to the Linksys router
The tech was correct about that matter. However you can configure the MAC to always allow the device.
  1. Find your MAC for NOOK. I think you have already did.
  2. Go to Setting and then to the Second Page to find it.
  • Configuring MAC
  • Wireless MAC Filter. To filter wireless users by MAC Address, either permitting or blocking access, click Enable.
  • If you do not wish to filter users by MAC Address, select Disable.
  • Prevent. Clicking this button will block wireless access by MAC Address.
  • Permit Only. Clicking this button will allow wireless access by MAC Address.
  • Edit MAC Address Filter List. Clicking this button will open the MAC Address Filter List. On this screen, you can list users, by MAC Address, to whom you wish to provide or block access. For easy reference, click the Wireless
  • Client MAC List button to display a list of network users by MAC Address.
  • Change these settings as described here and click the Save Settings button to apply your changes or Cancel Changes to cancel your changes.
Please rate the answer as well. Feel free to contact if you have any other problems or if this solution didn't solve the issue.
Thanks for contacting Fixya!
Posted on Jul 08, 2010
Download installation cd linksys wrt54gs
You could install the Linksys WRT54GS without any CD.
You could use the Linksys EasyLink Advisor to scan your network for the Linksys WRT54GS.
The Default IP-address is 192.168.1.1 so you should be able to connect to the Linksys with your Webbrowser when you do a factory reset of the Linksys.
Jan 26, 2014 | Trendware TEW-452BRP Wireless Router...
The password comes back as invalid when I just used the same password to connect my Windows based laptop and my iphone to the Wifi......
Report Trouble with Linksys router WRT54GS [Solved/Closed] johnkwit 2Posts June 16, 2008Registration date - Jun 17, 2008 11:17pm BST - Last answer on Jul 27, 2010 5:27am BST hello Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
Any help would be apreciated
Jan 05, 2011 | Computers & Internet
  • Configuring MAC
Jul 08, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54GS that is out of warranty. Power light keeps blinking on and off and unable to connect.
Blinking power is a sign that something is already wrong with the router, that can be a software of a hardware failure already, to fix this one lets reset the router by pressing the reset button of the router for 30 seconds while power is ON and then after that unplug the power for 10 seconds and check if the power will be solid....
Dec 07, 2009 | Linksys Wireless-G WRT54GS Router...
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
I lost my install disk and cust service is no help at linksys
http://www.linksysbycisco.com/US/en/support/WRT54GS/download
Rate fixya if helped
May 03, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Linksys wrt54gs won't work
Your router might need a restart to begin communicating with the modem again. Remove power from the router, wait a few seconds, then turn the power back on.
Nov 22, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless connection
through the static ip you need to aaply first 192.168.1.5 and subnet mask 255.255.255.0 after ping 192.168.1.1 it will works.
Oct 02, 2008 | Linksys Wireless-G WRT54G Router
WRT54GS version 6
Go to the linksys website at www.linksys.com, select your router, and you should find a link offering a driver download.
Apr 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
2,780 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
