Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Changed battery in remote. Do I need to re-sync the unit w/ button?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Directed Master
  • 2,226 Answers
You shouldn't have to.
Posted on Dec 29, 2010
I have a 2006 s type jaguar the remote control does not work and the inside trunk release button does not work also.
If u have taken more then ten minutes when you changed the battery the fob has probably lost its sync with the car n now u will need to reprogram, re sync or pair ur remote back up with the car
Feb 02, 2015 | 2006 Jaguar S-Type
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
My wii won't connect to the wii remotes - batteries have been changed
The wii motes and wii console may need to be re-synced. To do this, press the red button on the wii console which is located behind the front panel. The button is right next to the SD card slot.
Then turn on the wii motes so that the blue lights are blinking. Next, push the red button on the wii motes which is located behind the battery cover. This should sync the wii motes to the console.
Mar 05, 2011 | Nintendo Wii Console
Console does not respond to all remote actions, ie no cursor on screen,only the minus , home , and plus buttons work i have tried several remotes and changed the sensor bar.
I would try to re-sync the controller to the console.
1. Power on Wii
2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink.
3. Press the sync button on the console (it is located in the memory card holder on the front of the console)
4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii.
Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
Dec 31, 2010 | Nintendo Wii Console
Wii remotes arent connecting to the home unit, i did connect them to a differnt unit, now there refusing to connect to my home unit.
You just need to sync them to your Wii. Hold down the red "Sync" button on the Wii, located right under the SD card slot, while holding the red "Sync" button on your Wii Remote, located under the battery cover on the back of the remote. Now they should work!
Hope this helps!
Dec 25, 2009 | Nintendo Wii Console
Remotes don't work
on the battery pack of the remote there is a red button that says sync and there is a red button on the console by the sd card port press both of the buttons at the same time and it will work.
Mar 07, 2009 | Nintendo Wii Console
Wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Dec 29, 2008 | Nintendo Wii Console
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
87 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
