Hi I have a Sony receiver, which when switched on works fine.It is operating a plasma TV and the usual DVD/Radio etc After it is on for a few minutes, I hear this loud crackling noise ( through the speakers) and the SONY unit goes into protect mode, which means I lose all sound I thought about buying another receiver, but am puzzled as it still works, It does the same thing whether the mode is TV/Radio/CD/DVD Thanks for your help
  • michaelc292 Dec 29, 2010
    Thankyou
    I will try your suggestion
    BTW, which one is the HDMI cable, as there are many cables
    Thanks
  • 1,472 Answers
Michaelc292
What it sounds like is you may have a ground fault in your system some where. This can be caused by one of your devices or the receiver its self. Also you might have a bad HDMI cable as well. The first thing I would do is try another HDMI cable to see if you get the same problem. Next I would try unpluging your other devices from the receiver to see if the problem goes away. If you have a different HDMI cable and the receiver just connect to the TV then and you still have the problem then the issue would be with the receiver.
Now something you can try is to get a ground loop isolator to connect the the device to that is generating the gounding issue to remove the rogue power from the system. If the isolator does not fix the problem you will want to replace the device that is causing the problem as it can damage your other devices.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Dec 29, 2010
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
I have a Panasonic TX-P42VT20 and a SCART switching box from a number of devices (2nd Satellite receiver, DVD players etc.). This works fine with my old TV, but I only get sound and no video when I connect...
I expect the new Plasma is configured to RGB or S video. Check your menu settings and adjust to whatever the old TV was set at. Composite Video I suspect!
Feb 04, 2011 | Panasonic Televison & Video
My sony cdx s1000, the source button does not work,therefore i cannot get the radio to tune into any stations.the cd player works but the various buttons have no effect on volume,skip tracks,shuffle etc.
you may have a bad switch. if you can you can use a multimeter to check the resistance of the switches. anything less than a few megaohms, denotes a bad switch usually.
Nov 12, 2010 | Sony CDX-S1000 CD Player
Cannot even find where to plug to aerial point into the sony plasma flat panel display tv PFM-42V1
PFM-42V1 has no ability to receive channels through aerial / cable.
You can hook direct video cables from dvd player, vcr, PC etc.
Dec 07, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony DVD connected to HD system used to be regular colours, now it only shows shades of pink. .
dvd format must be compitable with tv-if it is compatible change your video cable with new good brand one from (radio shack)or any electronic store near you.
Jul 04, 2008 | Denon AVR588 Receiver
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
Programing Mode Backward
happy to help, just ask me here:)
regards
Graeme
Dec 04, 2007 | Onkyo TX-SR601 Receiver
Intermittent Sound from Home theatre system
confirm good wiring condition of celling speakers and disconnect it and connect it again-keep good ventilation around.
May 08, 2007 | Sony STR-DE598 Receiver
Unable to hear dvd audio when dvd playing on Sony STR-DE575
Hi The first thing to do is disconnect the red and white audio cables from the back of the receiver, and plug them directly into the tv. If you then have sound from the DVD, then you have eliminated the possability of no audio coming out of the DVD player. If the DVD player checks out fine, then I would try plugging the jacks into another aux input on the receiver, and select that and see what happens. Also, if there is a "tape monitor" button on your Sony, make sure it is turned off. I'll assume the receiver has sound from other functions, so it would be rare for one of the inputs to just stop working, (but certainly not impossible), I'm not familiar with that model, and normally I would say it could just be a dirty selector switch, but since you mentioned having a remote, then switching between inputs is done by the microprocessor, not a physical switch, so if you cannnot get sound through using another input, then it could be expensive to repair. Hope this helps, and good luck!
Apr 30, 2007 | Sony STR-DE575 Receiver
24 people viewed this question
 Grubhead
Grubhead
