Question about NEC VT465 Multimedia Projector
Replacing new lamp
I just took over using the NEC vt465 and have never replaced a lampo before. The lamp fits in percfectly, but it will notwork. The red light stays on. What am I doing wrong?
I do not have a manural.
Thanks,
**Help, I have class starting in 4 hours.
  • byoakum May 03, 2009
    no remote to reset bulb
    President:
  • 1,114 Answers
Hi - You can download the manual from the link below:
NEC vt465
Look at page E-30, make sure the cover is screwed up tight as there is an "interlock".
Most likely is the lamp hour meter needs reseting:
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 07, 2008
Where can I buy a new filter for a NEC VT465 projector
Contact the authorized service center for NEC. If you know the part number to it (refer its repair manual), you can buy it online from www.alibaba.com/
Electro help
Jul 23, 2014 | NEC VT465 Multimedia Projector
The power light is yellow and status light yellow
it seems the lamp is failing ,the price of the lamp is USD130
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | NEC VT465 Multimedia Projector
I replaced the projector lamp and still no light what am i missing. all i get is a solid red lamp indicator and a orange power indicator.
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Feb 10, 2011 | NEC VT465 Multimedia Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
My NEC VT465 shows a transparent yellow spot in the middle of the projected image.
I lent mine to a friend and it came back with this same problem - my guess is they wiped the lens with a solvent that messed up the lens coating the only solution is to get a new lens
May 12, 2009 | NEC VT465 Multimedia Projector
Need instructions for lamp unit part number TY-LA2004
the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Jan 28, 2009 | Office Equipment & Supplies
Reset a projector nec 575
If you mean the lamp timer, hold the help button on the remote for 10 seconds
Jan 06, 2009 | NEC VT465 Multimedia Projector
No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Jan 23, 2008 | Audio Players & Recorders
HP-070
Works for a few months?
Is this a new device -?
Check with seller and or makers help site.
Lamps guaranteed for 90 days and Machine for 2 years usually
Jan 15, 2008 | NEC VT465 Multimedia Projector
NEC VT465 Multimedia Projector Logo
261 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
