Question about HP Office Equipment & Supplies
I have mislaid my set up disk, and recently moved my computer. The computer recognises it but I cannot make connection, please can you help. I have HP Deskjet D2400 series. Not very technically minded. Many thanks Judith Preece
Many thanks, But I did manage to find my disc.
Judith Preece
Posted on Jul 10, 2008
The web camera cannot be detected
First ascertain the requirement of each devices either computer and camera to attain an experinces. Usually the camera requires a program either already provided on the computer or made installable from disk devices or network structures. Once the camera has been connected to computer, an expectation is either to display message prompt recognising the components or alternate. In the situation that the camera least was recognied on connnection has several causes. First, the computer or camera is least compartible in multimedia expectations. Second, the computer requires the component software program yet to be installed. Acquire devices on the retails market usually with cameras would have provided the complementary resources, programs, user guides on achieving an experience. Also, all recently innovated computer devices are manufactered capable of attaining multimedia experiences. In the sitaution that the camera or computer was not plug and play recognising connection immeidately, the manual search features have to be employed to make compartible functions. Once connecting a device to the computer, perform an update search to compile the new settings.
Feb 16, 2011 | Computers & Internet
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Have only just decided to install my new Iomega 500 GB usb 2.0 hard drive and I have mislaid my quick install guide. I have an Apple imac can you help please
Just connect the AC power to the IOMEGA, and the USB cable between the IOMEGA and a USB port on your computer. It is a "plug-and-play" device, and so Apple OS X should automatically recognize it.
Nov 21, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
My Samsung 250 GB portable HDD is not recognised now. It was working for last 2 years without any problem. Recently I found my PC infected by "WIN32" & Torjan viruses. It may be the reason. But I tried...
Try connecting it to another computer.
If it does not work, then either the disk-drive has failed,
or the USB-cable is damaged,
or the USB-to-disk-drive interface inside the case has failed.
Is the SAMSUNG still under warranty? (1 year? 2 years? 3 years?)
If so, SAMSUNG will replace it, at minimal cost to you.
Sep 25, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
May 12, 2010 | Computers & Internet
I have a Panasonic Inverter micro & Browner NN-GD546W. I have recently moved and we have mislaid the instruction booklet that came with it is there any chance that I can get another one please?
See Panasonic.net and look for the support or download links.
Jan 14, 2010 | Panasonic Microwave Ovens
Problem with Toshiba MK8025GAS hard disk
check the connection of the hard disk and make sure the cable is properly connected. also chek the setting on the CMOS. it should be recognised at CMOS level, make sure it is set on auto
Aug 21, 2009 | Computers & Internet
Hello
A new XP install,
If you have the original xp disk,
Insert the disk to the computer your setting up,
Turn on the power and let the system recognise the disk is in the tray.
It will prompt you and ask if you want to install the XP OS
Accept this and follow the prompts,
Windows will install itself over the old OS,
When completed it will then ask if you want to register the windows now or later.you choose and move on.
Activate windows now and the system will be funtional and ready to use....
Only other important thing to remember is to set up Computer Protection of some sort and have fun....
Hope this helps.Please let us know the outcome ,Thanks
Jul 15, 2008 | Computers & Internet
My hard disk
Hi, A few questions first.
Have you recently changed any hardware in your PC?
Have you recently had any power outs or surges?
Have you at all changed any settings in your system setup?
What type of hard drive is it?
What operating system are you using?
Please let me know
Nov 21, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
96 people viewed this question
Seeker5211
Seeker5211
