Question about Dmm Vision Fitness T9500 Treadmill
I get an E4 error message with my T9500 HRT Treadmill. What is the message indicate and how do I fix it. Powering on and off makes it go away.
Stuck key error on my treadmill
Sometime talcum powder under the thread will get it working again, but you may eventually need a new tread. Less likely, a problem with the motor especially if it's underpowered.
Jul 31, 2016 | Vision Fitness - T9800 HRT Full Commercial...
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Error messages error lines
    Dear Sir:
    Adjust the reed swtich see the diagram attached, clean, and tight the connector very well.
    tight the ribbon cable from keypad, and connector for display board vs lower board.
    If the problem persist you must run the software calibration for diagnose and troubleshooting.
    sincerely. God bless you
    Apr 26, 2012 | Vision Fitness T9500 Treadmill
    Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
    Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
    STEP 1 ENTER ENGINEERING MODE
    With the safety key in place, hold "ELEVATION UP" and "SPEED
    DOWN" buttons for 5 seconds. Software version will appear in display
    window for a few seconds before model displays.
    Press "STOP" , "ENG1" will appear in display window.
    STEP 2 AUTO-CALIBRATE
    Press "ELEVATION UP" until "ENG4" is displayed.
    Press "SELECT" , display will read "AUTO".
    Press "START". Unit will calibrate, when finished "END" appears in
    display window, then "ENG1".
    STEP 3 EXIT ENGINEERING
    Press and hold "STOP" to exit engineering mode
    I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
    If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
    Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
    I am getting a C4 on my T9350 Vission Fitness treamill. Please help. Thanks.
    Thanks for using Fixya.
    C4 error indicates Elevation error (signal lost).
    To remove it, check condition of all cables and cable connections and recalibrate
    Jan 10, 2010 | Dmm Vision Fitness T9500 Treadmill
    I have a Sears Pro Form 730si. The treadmill
    I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
    Jul 14, 2009 | Exercise & Fitness
    Dmm Vision Fitness T9500 Treadmill Logo
    178 people viewed this question
    Top Dmm Exercise & Fitness Experts
    fretlessbass
    fretlessbass
    Level 1 Expert
    Sportsmith LLC
    Sportsmith LLC
    Techmotionusa.com
    Techmotionusa.com
    Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
