Question about GE GSS25SGMBS Side by Side Refrigerator
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser stays open until freezer temp raises due to door being open.
  • chaserofthes Dec 29, 2010
    Turns out with a little disassembly that the top half of the coils were a solid chunk of ice. This leads me to believe the defroster thermostat is shot? All temp controls were set to the middle, 5.
  • 312 Answers
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Posted on Dec 29, 2010
  • 1 more comment
    Temp controls(freezer, freshness drawer) have both been set at the medium 5. I've tried colder settings on both and both the drawers and the freezer got colder, but the top shelf of the fridge remained around 50 degrees. I got curious and started disassembling the fridge, and found the top half of the coils a solid block of ice. Since this model has an automatic defrost, this leads me to think the defrost thermostat is shot. How close am I?
  • Mark Freedman
    Mark Freedman Dec 29, 2010
    If there was a SOLID chunk of frost, then the defrost system is not functioning properly. It can be one of 3 three things. The defrost thermostat as you noted. It's mounted on the coils near the top. It can be failed heater coils. (that model should have 3 of them wired in series). Or it can be the defrost timer. I don't know how old your fridge is, but most of the older ones had the timer mounted in the base behind the grill in the center. There is a metal bracket holding it in place.
    Here is the diagnostic sequence you can follow. That is if the unit has the a defrost timer in the base. It may also be located at the top of the fresh food compartment. Your are looking for a place to put a flat blade screwdriver into and rotate clockwise. If you find it, turn it very slowly until it clicks. At that point the compressor will turn off. See if the heating elements (quartz) illuminate. If they do, the timer needs to be replaced. If they don't come on
    The problem is not the timer (usually). Also the timer should resume operation of the compressor after about a half hour. If the problem is the timer, then you can hang the front panel covering the coils and run the defrost system until the frost melts away.
    You can visually inspect the heating elements to see if any of them have a burned spot where the wires are broken. If this is the case. you can replace them.
    The next thing is the defrost thermostat. If the coils are good from your visual inspection the culpret will then be the defrost thermostat. THAT has to be tested electrically at operating temperatures. So it must be frozen when it is tested. IF the elements are fine, the last thing is the defrost thermostat. Now this advise is given for most of the refrigerators made in the last 40 years, but not all of them. Your may have a very modern fridge which uses computerized components to replace the electrical parts used previously. Without knowing the model number, I'm blind on this issue. IF you know how to use a multimeter. Such as what is sold by Radio Shace for probably less then $20.00 or obtainable from Harbor Freight for about 6 dollars or less. Then that is the preferrable way to check electrical continuity in the various parts of a fridge. I hope this helps. Best Regards,
    Mark
    Now if the frost is melted away, i.e. you removed it. to test the defrost thermostat, it must be done at operating temperatures inside the coil enclosure. They are similar to light bulbs so if there
    The next thing is the heating elements.
  • Mark Freedman
    I posted a comment below to you and it labeled what as said as "guest" . After I say best regards, Mark, Skip the rest of it.
    Best Again,
    Mark
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Freezer working fine, but Refrigerator no longer cooling
Sounds like there's an airflow problem to the top section. Things that cause no cold air to the top fridge section are... frozen up coils completely blocking most of air flow (defrost cycle not working), evap fan not working to blow air up to fridge, air control dampers in fridge closed or not working properly, or frozen air ducts supply/return. Pull the whole drawer out the bottom and take the rear inside back off to expose the coils. If they are frozen solid the defrost t-stat or defrost timer could be bad (heat element not usually bad). If there is a nice white frost all over evenly then that's OK. Check that the fan is running when the compressor is running to blow the air up and that there are no blocked air ducts, etc. If all that is good, check if you can feel good air flow from the upper vents with the lower door closed (that shows there is no blockage and the fan is running).
Jan 06, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
951 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
