Question about Denon AH-D1001 Headphones
Can I replace plug on my Denon overear headphones
  • 30 Answers
If the cord is broken at the plug, most standard sub-mini,mini phone plugs can be replaced by someone with a little skill at soldering ( a ohm meter also helps). Get a replacement stereo plug like the old one (often at Radio shack or any electronic parts store). Cut off the old plug and carefully strip off the outside insulation back about 1/4". Note there is 3 conductors. The webbing around the 2 wires goes to the outside back end of the plug. This is the ground or common wire for both sides. This wire may have a non conducting coating on it which needs to be stripped off before you solder it to the plug. There is 2 other wires in the cord. one (often red) is the right channel and the other is the left. You can check which channel is the right side with a meter or a AA battery. DON'T try to check with the earphones on your head!! The right 'hot' side will go to the tip of the plug and the left side goes to the ring next to the tip. Don't forget to strip off the insulation of the wires by gently scraping them with a sharp knife or razer blade. Also don't do like I sometimes do and forget to put the collar or back piece on the wire before you solder the wires on the plug. Hope this helps.
Posted on Dec 29, 2010
Testimonial: "Complete description of procedure. Thanks"
I have a Denon 1513 that was working fine last night for the game. Got up today to watch redzone turn on clb/sat and no sound. Tuner works but no sound from tv. Unpluged optic wire from both. Help
Try plugging in and unplugging headphone to the headphone jack. This model has an intermittent problem with the headphone jack that makes the receiver think there are headphones plugged in even when there isn't. Inserting and removing a plug sometimes clears this.
Oct 18, 2015 | Denon Audio Players & Recorders
I have a Denon avr 391 and it worked fine for 4 years. Now I cannot get any sound out of it. Any idea what's going on. Help
could be a bad headphone jack. There was a commong problem with denon receivers around that time where the headphone jack had contacts that would short and make the unit act like there were headphone plugged in even when there wasn't. Sometimes you can clear the error by inserting a headphone plug and unplugging it a couple times. If it continues to happen, then you can get the headphone jack replaced.
Jan 04, 2015 | Denon Avr-391 Av Home Theater Receiver
Denon avr 1700 hp/only. how do I turn headphones off only?? I reset but did no work. can I clear the memory by unplug power, fuses ect??
try plugging in headphones and unplugging them. the headphone jacks have a tendency to have a shorted contact in them that cause the unit to think there are headphone plugged in all the time. Only true fix is to replace the headphone jack, but pluggin and unplugging can temporarily clean the fault usually.
Sep 27, 2014 | Denon AVR-1706 Receiver
My denon receiver keeps switching from H/P input on to H/P input off automatically which turns the sound on and off?
You need to replace the headphone jack. It has bad contacts that make the unit think there are headphones plugged into it. If you do not plan on using headphones, you can take the cover off and unplug the cable that goes to the headphone jack pcb and this should clear up the problem (please disconnect the power cord before trying this).
Aug 22, 2014 | Denon AVR-1909 Receiver
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
I have a Denon (receiver) DRA-825ra that has this issue: It powers on and you hear the first click sound right away, but the second click sound after five seconds does not activate. Can you help me...
Try plugging in headphones to the headphone jack, then take the plug out. Some models of Denon receivers had faulty headphone jacks in them that caused the unit to think there were headphones plugged in even when there wasn't.
Mar 22, 2013 | Audio Players & Recorders
My Skullcandy Hesh headphones have messed up sound with my ipod
I would say that if they work fine with other devices then your input jack on your ipod is bad. First I would plug other headphones into your Ipod and see if the problem persists. If not the case then I would plug in your headphones into a known working device and wiggle the wire at the connection point to see if you can duplicate the problem. If this does happen then you need to replace the connector (1/8th inch stereo male plug) on your headphones.
Oct 22, 2012 | Skullcandy Hesh Overear Headphone...
My Denon AVR 1708 display shows "h/p only", which
Hi
H/P means Headphone .. if you plugged a Headphone or if the plug switch internally switched to H/P you have to check it out .
you might have broken the plug inside or some parts are left in there.
Regards
Nov 02, 2017 | Denon AVR-1708 Receiver
The conection plug broke.
See if my tip on headphones will help you with this problem.
Apr 05, 2010 | Denon AH-C751K Headphones
Denon AH-D1001 Headphones Logo
452 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
