Wind direction on my brand new wmr80a is about 90 degrees off . I have tried taping the vane pointing directly north and resetting after doing a battery disconnect and searching with the base. this did not reset the pointer on the base to No. Also, I noticed tonight, some segments of the numerals of the clock are missing and the time is incorrect and not communicating. This is a new problem and all had been working fine except wind direction since Christmas.Please reassure me these are minor problems that can be calibrated or corrected. Batteries are brand new lithium.
  • 12,061 Answers
Unfortunately as much as i would like to reassure you, unfortunately, these symptoms, indicate that there is some internal microprocessor problem, and the unit should be taken in for a repair/service.
Ask for a "Quote" for any re;pair to be done.
Posted on Dec 29, 2010
The XC0369 weather station when used in the Southern hemisphere has the solar cell used to charge the batteries facing away from the sun when aligned north.
if you can --put the solar panel horizontal so that it doesn't matter where the sun is
the solar panel works from ultraviolet rays and not direction so if you are doing what you are there is another problem with assembly
May 26, 2017 | Sun Computers & Internet
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
How do I know which direction to point my TV antenna?
Well TV transmitter stations are usually located on top of high hills or really tall buildings. So you want to point your antenna towards something tall. If you live in a largely flat area just face it straight up.
Jan 31, 2013 | Electronics - Others
1998 chevy lumina shuts off while idling..ex. sitting at a stop light
sounds to me like the fuel pump or the fuel filter are bad
Jul 17, 2012 | 1998 Chevrolet Lumina
How does a compass always point to due north?
"Due North," by definition, is the direction towards the earth's north pole; or, visually at night, towards Polaris, the north star. Therefore, compasses generally do NOT point towards due North but, rather, point towards "magnetic north," as the other responder described, which is a variably located at some distance from True North, depending upon where the north-locating compass is situated on our planet. In most circumstances magnetic North is close enough so that people are willing to accept it as North in general terms. However, depending on your location, and upon seasonal changes caused by Earth's wobbling rotation (called precession) true North can be many degrees off from magnetic (from your compass's) North. In those cases true North must be determined using declination charts, which will tell you how many degrees to add or subtract on you compass in order to determine true North by the Magnetic North your compass is pointing to. For example, if magnetic North is 10 degrees west of true North at your compass's location (that is, your compass is actually pointing 10 degrees to the "left" of North), then you would correct by considering the +10-degree bearing point on your compass dial as True North--and, likewise, add 10 degrees to any bearing line you happen to determine using your compass. You have one other way of finding True North, which is celestially, by sighting towards the Pole star, aka Polaris, aka the North Star...that is, providing that the sky is UNcloudy and unsunny enough for the star to be visible. Of course, that only works for those located in the morthern hemisphere. Those south of the equator have a "south pole" star but it is not as accurate as Polaris in the northern hemisphere.
Jul 09, 2012 | Camping, Backpacking & Hiking
How do I use an orienteering compass to measure inclination?
Declanation (not inclanation) is different depending where you are located in the world. You can look up charts (magnetic lateral lines) on the net and they will tell you where your compass is pointing to, Magnetic north compared to TRUE north... Topographical maps will tell you how much to offset your compass to accomodate for declination...In degrees. I am no expert but I hope this steers you in the right direction. P.S. A compass always points to magnetic north not true north. Also I am not responsible for you getting lost ! lol
Oct 09, 2009 | Compass 337 "rothco" Orienteering
Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Trig and distance
Debs,
this is solved by starting with the SECOND leg of the flight considered as a triangle.
Find how far DUE east the plane travels (100 km x Cos10 = 83.9 km) using 10 degrees because that is how much is left of the 90 degree quadrent after subtracting the 80 degrres course direction.
Similarly find out how far DUE north the plane travels (100 km x Cos80 = 11 km).
Now get the total flight NORTH = 300 + 11 = 311
- and total EAST = 83.9
Finally, use Pythagoras theorem.to get the total DISTANCE:
square root of ( 311 squared + 83 squared ) = 321 km
Also the DIRECTION from its Tangent of 83 /311 = 14.9 degrees
Dec 19, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Feb 16, 2008 | Dishwashers
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
