Question about Kenmore Washing Machines
I have a kenmore washer 90 series model 110.20912 990 the drum will not turn. it will bump when engaged but will not spin.
  • 1937 Answers
SOURCE: Kenmore 90 series Model 110 20902 990 does not
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20902990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part (about $37) and only requires you to access the console and remove the cabinet.
Posted on May 26, 2010
the dr
  • 447 Answers
SOURCE: kenmore washer drains but won't spin.
Sounds like the motor coupling has broken, fairly inexpensive part but does require some finesse to install. let me know if you decide to attempt it.
Posted on Oct 15, 2007
catriver
  • 878 Answers
SOURCE: Kenmore washer 90 series wont spin
If your trans and coupler are good then I would suspect the drive block or spin tube. You will have to remove the trans to change out the spin tube. Take out the basket, there should be 2 ears from the spin tube that nest in the drive block. Attached is a photo to help you understand. Before all this make sure nothing is caught between the basket and the tub. Catriverd8086fb.jpg
Posted on Nov 27, 2007
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
aborcass
  • 2651 Answers
SOURCE: Kenmore washer 110 20912 990 will not spin or empty
sounds like perhaps you dissconnected the door latch assy,and never reconnected??? hte unit will not spin/drain with the door latch not making contact
Posted on Dec 14, 2008
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Kenmore 90 series , Brake doesn't engage basket after spin
This assumes that you have a basic Sears / Kenmore / Whirlpool top load, direct drive washer.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the Sears diagram or the following Whirlpool Service manual
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
It sounds as if your brake shoes are worn / damaged.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
I'd pull the drive tube and check the springs, shoes and plastic cam that hooks onto the clutch spring.
Although Sears sells a complete drive tube assembly, you can probably get only the parts you need (shoes) from Whirlpool.
Mar 04, 2010 | Kenmore Washing Machines
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Dec 19, 2007 | Washing Machines
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
153 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
