Question about Compaq CQ60-215DX Notebook
My keyboard has locked up, what do I need to do to get it to work again?
  • 312 Answers
Reboot. Now if you cannot do this because of the keyboard, don't fret. Hold the power button down for about 5 seconds. It should simply shut downthe laptop complete. Push the button again normally and let it fully reboot. Don't worry about damaging the machine. You won't hurt it.
Hope this helps,
Best Regards,
Mark
Posted on Dec 29, 2010
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
My problem is with the keyboard. I seem to have locked the keys somehow. How do i get the keyboard to work properly again for lowe caser typing? I'm not sure what to press to do so. My acer laptop is acer...
Greetings,
Look for the Caps Lock key and press it once, try typing again.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 03, 2008 | Acer Computers & Internet
HOW TO SWITCH BETWEEN NUMBERS AND LETTERS
I'm guessing this is on a laptop or mini keyboard? You have managed to turn them number lock on. To be able to use the letters again on the keyboard the number lock feature needs to be turned off. This varies depending on the model of keyboard/laptop. One thing that may help is using the fn (lower left on keyboard) key on laptops (funtion key) and while pressing this tap the Num Lock key, usually at the top right of the keyboard.
difficult to be specific without knowing the exact make/model.
Dec 08, 2013 | LG ELECTRONICS Remote Control 26378154...
Toshiba laptop keyboard stops working
there are screws marked symbol of keyboard on the bottom side of laptop. unscrew them, carefully unlock the locks which are on sides of the keyboard. just slightly lift the key board. under the keyboard u will see that a cable is connected to the mother board. open the lock of the keyboard cable & put it again in socket. if k/b still not working u need to replace the keyboard.
Sep 21, 2011 | Compaq Keyboard
My keyboard stopped working after my dad threw a pillow on it absent mindedly, and it messed with my normal keyboard now it just doesn't work at all, its really annoying, i tried new batteries,...
Hi supercrapnst ,
Please follow the below steps..:)
  1. Please make sure that you get your keyboard replaced , in case it's still under warranty , hopefully the supplier would give you a direct replacement.
  2. Check if the keyboard works when connected to your friend's pc , so that you are confirmed that it's not just your pc that is having an issue with the keyboard.
  3. Check if there is any lock key function on the keyboard which locks all the keys together so that you unlock them again with the relevant command , please refer to the manual or the icons on your keyboard , as there are some keyboards which provide this option.
  4. Check the device manger settings, via right clicking on my computer icon --> properties --> hardware --> device manager and see if the keyboard is detected as working properly , if there is an error , you need to reinstall the key board driver and hopefully it will work.
Hope this helps ..:)
May 11, 2011 | Memorex RF 7000 Wireless EZ Touch Keyboard
HP G60-235DX keyboard not working at all
Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
Aug 22, 2010 | HP G60-235DX Notebook
How do you unlock the CAPS lock
To unlock the caps lock on your keyboard, please click on the caps lock key again.
Check for few iluminating lights on your keyboard as well, as few of the models does have that.
If the Caps lock is ON the lights normally illuminate and If you click on the caps lock key again, the lights go off.
Feb 07, 2010 | Gateway 2520915 Keyboard
I can't type anything on my keyboard. How do you
I donot think there is a lock key on the keyboard only if you have special one, there is only Num lock which lock only the numbers, but make sure your cable is plugged well from the computer side, disconnect and connected again, restart the computer and try again. it should work.
Thanks for using Fixya
Oct 14, 2009 | HP Pavilion 6730 PC Desktop
Numbers not working
On keyboard press number /try again restart the computer and try again.
Jan 07, 2008 | Targus USB Ultra Mini Keypad Keyboard...
Compaq CQ60-215DX Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
