Question about Watches
My Lacrosse radio controlled digital watch had the battery changed The Display shows _ _ _ How do I set the time.
  • 3,083 Answers
You have to put the radio near a window and leave it overnight. At night, it will receive the WWV signal and set itself, usually from midnight to 6 a.m.
I had one, and it set itself at 9 p.m. that night.
Make sure it's not around any electrical interference- computers, etc.
If you have heavy electrical lines around your house, you may have to leave the watch somewhere else overnight, where it will receive the signal.
Lastly, if it doesn't reset, exchange it, but it will probably be ok.
Good luck, and hope this helps.
Posted on Dec 29, 2010
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
Tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Crane & Villeroy watch (radio controlled) After fitting a new battery it shows the time 1 hour behind the correct time.
    It sounds like your watch is on daylight saving time (DST) or it is set to the wrong time zone.
    If you press the "Mode" button you will enter the settings menu and you should be able to change this by pressing one of the other buttons. Some experimenting will be needed.
    Sep 18, 2010 | Watches
    Setting after battery replacement
    I sent my Lacrose radio controlled watch out to have the battery was changed now the vendor says that the display is _ _ _
    what do I or the vendor do to set the the watch again
    My email is georgesaufley@yahoo.com
    Aug 29, 2010 | La Crosse Radio Controlled Watch
    Hi i have a radio controlled watch 3atm with a small digital display and 4 buttoms on it i cant st the time on it other wise its ok and i dont have a manual
    If the time is "incorrect" i.e. not your local time, then it is set to another time zone.
    To correct this press the "mode" button until you come to a display showing three letters. These are city abbreviations and you may have to guess which one you need.
    Some experimenting will be required, good luck!
    Aug 24, 2010 | Watches
    Roberto vecci radio controlled watch instructions i cant set the analoge time
    i HAVE RDIO CONTROLLED WATCH NUBER 02390 PUT A NEW BATTIER INIT BUT i CANT GET IT WORK RIGHT,DAVID
    May 20, 2010 | Fossil Watch
    The digital display shows the correct time but the hands do not.
    hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
    Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
    How do I set a LaCrosse WT-961 (B) watch?
    This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
    Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
    Mar 07, 2008 | La Crosse Radio Controlled Watch
    Fossil Big Tic Watch - setting the correct time on the digital display
    The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
    Oct 25, 2007 | Fossil JR8096 Wrist Watch
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
