I have a Vaillant Geyser Premium Turbo water heater, running on propane. It works fine when running flat out, or with no cold water added to the mixer, e.g. at the shower. But if you want to start adding cold water to the mixer - if you add too much (thereby starving the heater of the cold supply ) it cuts out. It seems unreasonably sensitive to the change in water pressure as I have pretty good mains pressure. It has always been like this from new, and nothing obviously wrong with the installation, no leaks, blockages etc.
You need an "anti scald" shower valve .
Posted on Dec 28, 2010
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Water Heaters
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
What is an anode in a geyser
The anode rod is part of water heater, not part of geyser:
Here are anode rod resources:
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
The geyser is compressor that attaches to top of water heater, and converts ambient room temperature into heat to heat water using the refrigeration cycle in reverse
Add a comment and fixya might notify me so i can more informeation if needed
Jul 08, 2013 | Water Heaters
Hi my vaillant combi gives hot water for only 15 seconds then runs cold turn the tap off, run the water again & gets hot then runs cold some told me it might be the diverter valve can any body help...
yes it is your expansion vessel it sounds under charged to me?your expansion vessel needs to be recharged to 1 bar at least,but check manufacturers instructions it could state different.if the heating is fine and your getting hot water in intervals your diverta valve is moving and working?
Dec 11, 2012 | Water Heaters
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Jan 20, 2009 | Water Heaters
Heating & Cooling Logo
581 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
