Have a new Virgin box and have just bought a new VCR. We have Cable and the cable arial goes into the V so how do we connect the ariel to the VCR?
Thanks for contacting me. We have a computer guru (everyone should have one) who we called and he sorted out the mistake the Virgin+ installer made; he had plugged the ariel lead into the Virgin box. All tested and working fine now.
When all else fails we call for Gary who also has elderly parents needing help. So spend a little and get lots of help.
Regards,
2 x 70+ yearolds!
Posted on Jul 08, 2008
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
How do I connect a virgin v box to an old lg model?
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Nov 07, 2014 | LG Televison & Video
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Connecting cisco 851 cable to virgin media superhub problems?
Did you follow instructions on the manual , re install the driver .
Dec 27, 2013 | Cisco Computers & Internet
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
Apr 30, 2012 | Lite On HD-A760GX DVD Recorder / HDD...
VCR doesn't work when installed between cable box and TV
a simple way is to get an AV switch .
you may like to try connecting it with different cables
May 07, 2009 | Televison & Video
Magnavox DVD/VCR Dual
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
No channels
are you plugging it into the actuall cable or is it an arial socket if it is the cable you need a cable box as you change the channels on this if it is the arial then it should have a self scan mode in the setup you wont get cable channels without a cable box because they opperate at different frequency and the newer tellt are made not to pick up these frequency so you have to purchase the cable box this should be plugged into your telly via a scart lead then you change the channels on the cable box the only channel maybe it is different as i live in the uk sorry i couldnt bbe any more help
Oct 31, 2007 | Proscan PS32600 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
