Question about Eclipse CLD2 MP3 Player
No connection to computer. When first plugged in it will go into charge mode and then windows 7 says it does not have all the drivers to install this device. Then the mp3 player turns off and the computer does not reconize it. thompson9875@roadrunner.com
  • 10,421 Answers
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
Tip
Sansa View: is not recognized by my computer
See myother TIP posted here on this site. About MSC and MTP Connection problems.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
First thing to do is:
Try otherUSB ports on your computer. A USB port on the back of a PC usually has better poweroutput.
Try adifferent cable if there's one available, to rule out if you have a bad cable.
Tryanother computer.
If none of the above works:
Then-Check and refresh the drivers in Windows, for a Portable Device.
1 -Connect your player to the PC
2 -Check under Device Manager
-> 1.Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2.Portable Device (if the player is set to MTP mode.)
(See my other TIP listed above for an Explanation of MSC and MTP modes)
If thereis a yellow exclamation point (!) or question mark (?) beside the device, tryto refresh the drivers.
Then -Refresh the drivers
1.Right-click the entry with the error mark, select Uninstall.
2. On thetop menu, click Action then select Scan for hardware changes.
If your BRAND NEW player is NOT recognized by the computer when plugged in:
This may becaused by one of the following:
1.Minimum system requirements were not met.
2.Corrupted drivers.
3.Computer restrictions, Vista or 7 authorizations.
4. Powerissue, plug your player into the back of the computer.
Next be sure you are using WindowsMedia player :
Version10 or 11
Downloadand install the latest Windows Media Player if it's not installed.
If all this has failed - Refresh the drivers again.
If allthat does not work - Manually add the hardware driver.
1. Connect the Sansa player in MTP mode
2. Manually install the device driver through Windows device manager in control panel. Install the Device as a Portable Device.
on Jan 11, 2010 | Audio Players & Recorders
Gateway dx4300-11 won't power on after put in
Is the Gateway DX4300 having problems while installing the drivers after sleep mode
or does it have these problems during the laptop is turned on.
Always make sure you download the right drivers for your system.
If you installed Windows Vista after you had formatted the system and now your trying
to install them you might want to go on another system and download all of the drivers either on an external hard drive or an SD card so everything can be accessible.
After you install Windows Vista or 7 make sure that the compatibility mode is selected while installing the drivers.
Most of Gateway drivers are Windows XP so you have to go and right click on each and every driver and change the compatibility mode to Windows XP SP2 that way when you let it install then Windows Update will activate to perform updates for hardware drivers and software applications. It will also get the KB updates for your computer.
This will probably fix the sleep mode and improve it too.
1. Go on Gateway's site
2. Download the DX4300-11 drivers and make sure its directly from
Gateway on a SD card or external hard drive.
3. Change the compatibility mode to Windows XP SP2
and let it run as administrator.
Each driver will then install and then you will fully use
your computer's capability.
After the drivers are installed then change your power options
as it will continue to install your drivers.
Check to make sure that your battery is fully charged and is plugged in
if it is. If not plug in for charging the battery.
If all fails then you will need to replace the motherboard.
Sep 26, 2011 | Gateway Computers & Internet
Ebookman EBM-901 not being recognized as connected on Windows 7 x64. Windows troubleshooting says USB Virtualization stub has a problem, suggests reinstalling, attempts that, then says it failed to fix...
Welcome to FixYa!
Install the drivers supplied by the manufacturer in Windows XP SP2 compatibility mode.
First, restart the computer is clean mode. The Clean Mode temporarily disables all the programs that are being loaded during the startup of your computer.
  • Click start.
  • Type msconfig in the search box.
  • Click on msconfig from the results.
  • System Configuration Window will open.
  • Click the Service tab.
  • Check the box that says Hide all Microsoft services on the lower left corner of the window.
  • Uncheck all the boxes in the list.
  • Click the Startup tab.
  • Click on the Apply button.
  • Click the OK button.
  • You will be prompted to Restart.
  • Click Restart.
Install the driver in compatibility mode.
  • Locate the driver installer file (Application file with .EXE extension)
  • Right click on it. Click Properties.
  1. Click the Compatibility tab.
  2. Tick the check box that says Run in compatibility mode for.
  3. Choose Windows XP SP2 (Service Pack 2). Do not choose Windows Vista.
  4. Tic the check box that says Run this program as administrator.
  5. Click Apply.
  6. Click OK.
  • Connect the EBM-901 to the computer.
  • Double click the driver installer file to start the installation.
  • You may be required to restart after the installation.
Thank you for using Fixya. Have a great day.
Jas247
Jul 21, 2011 | Franklin Electronic Publishers, Inc....
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
How connect to windows 7
This device does not support windows 7 and there is no driver for it. You can connect it to windows 7 though if you install windows XP compatibility mode for windows 7.
You can download and install this mode from this link to Microsoft: http://www.microsoft.com/windows/virtual-pc/download.aspx
Please note: Windows XP mode for Windows 7 uses resources so it is good if you have at least 4GB of RAM.
Chris
May 20, 2011 | Agfa SnapScan 1212u Flatbed Scanner
I need drivers for cannon printer BJC 85 to run on windows 7
There are no officially supported Windows 7 or Windows Vista drivers for the Canon BJC-85 printer. If you have the 64 bit version of Windows 7, then you have no choice other than to buy a new printer or use this printer in Windows XP Mode. If you have Windows 7 64 bit then please post back here with that information or create a new FixYa problem, and I will help you set up XP Mode so that you can use your printer.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Assuming you have the 32 bit version of Windows 7:
1. Go ahead and download and install the XP drivers by following the link and clicking on "I Agree - Begin Download". Here are the drivers for Windows XP: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/bjc_series/bjc_85#DriversAndSoftware
2. Save file to the Desktop for easy access.
3. Right click on the downloaded file and select "Properties".
4. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows XP (Service Pack 2)".
5. If the installer completes, then restart the computer and attempt to print from the Canon.
If the installer fails follow the next set of directions:
1. Make sure the printer is plugged in, turned on, and connected to the computer via USB.
2. Press Win+R to open Run command.
3. Type "DEVMGMT.MSC" and press enter.
4. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "USB Input Device" or "Unknown USB Input Device".
5. Right click on the device that has a yellow exclamation point next to it and select Properties.
6. Click the Driver tab and select Update Driver.
7. Click "Browse my computer for driver software".
8. Select "Let me pick from a list of device drivers on my computer".
9. Scroll down to "Printers" and select Next.
10. Click "Have Disk" and select "Browse"
11. Browse to "C:\Temp\bjc85Win2kXPv150" and select "bjc85.inf" and then click Open and then OK.
12. Ignore all errors that Windows gives you and install the driver, restart the computer, and attempt to print.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 06, 2011 | Cannon BJC-80 Printer Driver
I download the drivers but when I go to install it says it cannot find them
Depending on the make and model of your computer and operating system, you'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until you're prompted to restart your computer.
Restart your computer.
Install the proper drivers. You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
If using Windows 7, install the Vista drivers in the compatibility mode. Vista 32-bit for Windows 7 32-bit and Vista 64-bit for Windows 7 64-bit.
Links to the patch/drivers and installing in the compatibility mode can be found at...
924 Photo All-In-One Printer owners thread (W7)
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
Microtk Scanmaker 3840 driver for windows 7
The scanner is not supported by Microtek for Win7. Since Windows 7 didn't find a generic driver (TWAIN) in its driver code, one option exists in Windows 7 Pro and Ultimate. Download and install the virtual XP mode (two programs are needed), then use the XP drivers and install the scanner to the "XP computer". You may need to store files on external media to transfer them between the "two" computers.
The XP drivers are here:
http://support.microtek.com/product_dtl_2.phtml?prod_id=32
I hope this helps.
Feb 26, 2010 | Microtek scanmaker 3840
Printer will not operate on Windows 7 computer.Computer was upgraded from Vista to 7. Vista was completely removed before installing 7. Tried downloading new drivers, didnot work.
Possibly HP rare not supporting this printer in the new OS, although most Vista drivers are compatible with Windows 7, so have you tried installing the original drivers that came with the printer?
Also, Windows 7 has a driver "compatibility mode". Here is use of the mode explained on the Microsoft tech forum:
http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/80cae5ee-dc98-4a2f-8284-a1ab826059b7
Feb 05, 2010 | HP Deskjet D4260 Printer
Eclipse CLD2 MP3 Player Logo
529 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
