Question about Amana ABB1927DE Bottom Freezer Refrigerator
The freezer area makes constant noises groaning whne door is closed, stops when door is opened
    Sergeant:
  • 223 Answers
I'm going to say it's a bad bearing in the fan. It shuts off when the door is opened so as to waste as little coldness as possible.
lp
Posted on Dec 29, 2010
How do I repair a Freezer fan not working
mount out the fan and replace it with a new one.
Mar 27, 2012 | Refrigerators
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
Gr Side-by-side refrigerator freezer makes noise when door close
It is possible that the hinges of your freezer has moved and shifted the alignment. So first of all use a WD40 cleaner to spray into the hinges and the areas around it. Now move the hinges violently for some time and check if has lessened. If so repeat the spraying. See if here is dirt accumulated along the hinges if the door is not moving parallel just push the end up a little . You must be able to get the hinge to shut properly by this correction. Hope you try . Good day
Jul 31, 2010 | GE Refrigerators
Fridge Freezer makes 'groaning' noises
Sounds like it could be the icemaker . If the icemaker heater is bad , (replace icemaker ) , then it will groan while trying to dump the ice .You can try turning the icemaker off for a day and see if that stops the noise .
Aug 29, 2009 | Refrigerators
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Kenmore Elite Trio makes creaking/groaning sounds
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jan 30, 2009 | Jenn-Air JFC2089HE French Door...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Amana ABB1927DE Bottom Freezer Refrigerator Logo
156 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
