Due to near thunderstorm I unplugged my Edimax AR-7024Wg. On switching the power back on the Edimax has stopped working. My only attempts at restoring it are 1. pushing the reset button (lights come on whilst holding it in but go out as soon as I release reset button) and 2. disconnecting power cable from back of router. Nothing!
    Genius:
  • 1,665 Answers
Reset button may be faulty. it may needs to be replaced
Posted on Jul 07, 2008
Edimax ar7284wna
When you reset the device it returns to original default settings, your SSID and Security Key is gone, you must reconfigure the Device. perhaps this will help: http://www.edimax.eu/images/Image/product/AR/AR-7284WnA/manual/AR-7284WnA_UserManual-20091119.pdf
May 04, 2013 | Computers & Internet
The display is suddenly filled with information (sometimes unreadable). Everything has now stopped working.
From the sounds of it the microprocessor is scrambled, this can be caused by a power surge or thunderstorm, unplug unit, press and hold power button for 60 seconds in an attempt to clear the processor, if this fails this will be a job for a Bose factory trained technician.
Sep 16, 2012 | Bose Wave Radio
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
Aug 14, 2012 | Edimax EW7416APn (EW7416APN) Pre80211n...
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
Apr 04, 2012 | Edimax Computers & Internet
Edimax ES 3105P 5 port ethernet switch. I am wondering if in some way it is possible to manually reset this device. Because on the outside of the box there arent any reset buttons. I have set up my...
hi there; your switch hub has no reset button, only router has a reset button for factory default, you can only reset it by unplugging the power adapter, router has WAN connection try to check your other device, thanks ,,,
Sep 21, 2011 | Edimax ES 3105P (ES-3105P) Networking...
Hp Pavilion a1120n will not power up.
Yes it needs a power supply. You can get a cheep one on eaby or get one off of the HP site
Hope this works,
Luke Wilcox
Dec 28, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
Jun 15, 2009 | Dryers
Edimax ar-7084
hi, contacted edimax and was told how to reboot the router without the disc, my original problem was a faulty filter on the telephone line which caused an ASDL failure. hope this helps
bill
Nov 19, 2008 | Edimax Computers & Internet
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
55 people viewed this question
jasbo
jasbo
