Question about Honeywell Programmable Thermostat Heater
I have a older thermostat the kind that you just go forward and back to ajust the heat but no heat comes out of the heaters that i have they are the older heaters that are along the side of the floor im not sure if it is the thermostat or the heaters itself trying to call the lanlord but he keeps tellin me hes going to fix it how can i fix it or find out what the problem is im getting fed up my apartment is very cold im using a electric heater
    Novelist:
    Champion:
  • 224 Answers
A simple way to test to see which is bad is, remove the thermostat from it's mounting base, on the back there are wires locate the red and white and place a jumper from one to the other. Now that the red and white are jumped together your heaters should be heating up, If they are it is a thermostat problem, if they are not heating it is a problem with the heaters. This is a simple way to test, the heaters should run they just will not shut off until you remove the wire that jumps the two together.
Posted on Dec 29, 2010
  • spicekee Jan 11, 2011
    Can u leave the jumpers connected until the thermostat is replaced?
  • jmonoski Jan 11, 2011
    You shouldn't because this makes the heater run all day all the time unregulated, it would be real easy to over heat these base board heaters. I do this only for test purposes, and trouble shooting. You have to act as the thermostat and cut the heaters off every once in a while, I am not saying yes but also am not saying no. This has to be only used as a temporary thing until you purchase a new thermostat, please do not use it like this for extended periods of time.
Older pictures of honey wells
Paula, remove the cover of the thermostat and look for a model number. The actual thermostat may have to be removed from the sub-base to find it. There may be either a long line of pins on the sub base that matches up with holes on the back of the thermostat when you re attach it....or there may simply be a 3" long ribbon connector that makes the connection.
Once you have the correct model number call Honeywell Customer Service at 1 877 841 2840 and work your way through the menu until you get to 'if you a homeowner push this number'. Once in touch with a live troubleshooter, they should be able to assist you in programming. You should know what kind of system you have, gas, electric or heat pump heat with central air.
You MUST have the correct model number BEFORE you call.
Nov 10, 2015 | Honeywell Programmable Thermostat Heater
Boiler runs to long
Adjust the high limit on the control.
Dec 07, 2013 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
NO Heat
I'm assuming it's an electic unit. Check the fuses to the heater which can be seperate in an older air handler. If the fuses are good, then it's probable that the sequencer is bad or the fan relay switch is bad. It is also possibe that the heat side of the thermostat is bad. You can check this by removing the thermostat exposing the tstat wires and terminals. Take a small wire and jump from the RC/RH terminal over to the W terminal. If the heat comes on, then it's the thermostat. Hope this helps!
Mar 20, 2009 | Heating & Cooling
BOUGHT AND REPLACED A HONEYWELL ROUND THERMOSTAT AND THE HEAT WILL GO ON BUT WILL NOT SHUT ITSELF OFF WHEN THE TEMPERATURE GETS TO THERE. IT KEEPS RUNNING TILL I SHUT THE THERMOSTAT OFF. I FOLLOWED THE...
look at the old thermostat and in the middle of it theres a arrow that is pointing at numbers that is called a heat anticipator. then on the new thermostat make sure that its set the same.
Feb 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
No heat
You probably just need to backflush your heater core. You can use a hose to flush it back and then forward. You'll be surprised at how much sludge and gunk will come out.
Jan 21, 2009 | 2004 Dodge Ram 1500
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 | Ovens
Goodman Furnaces
what kind of thermostat do you have? make sure all wires are hooked up on thermostat properly for emergency heat operation. hope this helps
Jan 05, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
321 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
