Cannot remove broken needle from machine. - Office Equipment & Supplies
    Guru:
  • 1,833 Answers
You have to dismantle the roller assembly from the back side. Then you can remove the broken needle.
Posted on Jan 03, 2011
How to remove broken off needle from pfaff machine why is bobbin not working
Where is the broken needle stuck? The broken upper part should just come out like a regular needle (via the needle-screw). If the broken tip is stuck, try removing the bobbin case from the machine. When that is released, everything under the needleplate should be accessible.
If the needle is hitting, most likely your machine has been knocked out of time (which frequently occurs when the needle strikes something it shouldn't). Search for sewing machine timing or take it for service.
Apr 14, 2017 | PfaFF Sewing Machines
NEEDLE BROKE OFF & BOTTOM HALF FELL INTO WHERE BOBBIN IS. WILL IT INTERFERE WITH SEWING. CAN'T SEEM TO FIND IT TO REMOVE. PFAFF HOBBY GRAND QUILTER 1200. THANK YOU
If it is stuck in the bobbin mechanism, you can remove the bobbin case to extract it. You probably should find and remove the broken piece because it can cause severe damage to your machine. I've actually picked my machine up and shook it to find the broken needle. Sometimes it drops straight through and is actually setting under the machine.
Feb 08, 2017 | Sewing Machines
Upperlooper needle is broken
do you need to find a place to get more needles?
Apr 21, 2016 | Sewing Machines
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
The screw on the needle bar is broken can't get the needle out the screw broke flush to the needle bar . what do I do.
hi
it's easy don't worry about that , just try to move needle to left and right before start to remove broken scrw, you can catch needle by and spanner. second after removed needle by pull it down ( it's not so easy to remove but try also by spanner. just bring any needle with thick size ( 18 or 23 ) and try slowly move the broken scrw to counterclockwise direction . it will takes long time but at final broken scrw will out of needle bar.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
May 22, 2015 | Juki DDL-8700
How to chang ethe needle
there should be a little hand screw near the top of the needle, loosen it enough to slide the broken needle out, replace with a new needle and tighten, Just remember, if you don't have the needle in properly you will ave issues. Usually, the flat part of the needle goes to the right, I have a brother sewing machine and the flat part on mune goes to the back though. Just take note when you remove the old needle as to the position. Also, a little known fact, a sewing machine needle should be replaced after 8 hours of use.
Jan 16, 2014 | Sewing Machines
Broken needle in machine
if the needle is still in the machine, remove the needle plate & see if you can remove the parts of the needle that way.
May 02, 2012 | Bernina Artista 180
Change needle?
If you are asking if you should change the needle, yes. My experience is that a dull needle will cause problems long before it breaks. If you are asking how to change the needle, then: first raise and then remove the foot (not really necessary but makes it easier) If possible do not remove the screw that secures the foot. Next loosen the small screw that secures the old/broken needle in place. Remove the old/broken needle, paying close attention to the needle's alignment (which direction is the flat side of the shaft facing) Insert the new needle with the same alignment as the old needle. Tighten the small securing screw, replace the foot and tighten the screw that holds it in place. Rotate the machine by hand to insure that the new needle does not strike or rub against anything during it's full cycle. Sometimes a broken needle will indicate a timing problem or a incorrectly installed bobbin holder. Re-thread the machine and check for proper operation.
May 16, 2011 | Euro-Pro Deluxe 7100 Mechanical Sewing...
Broken needle
Remove the needle plate and Turn the machine upside down and shake it or just leave it alone. It will not get into your gears. If you can see the needle you can take it out with some tweezers.
sewman7
Jun 17, 2008 | Brother Sewing Machines
Needle broken in the needle-slot
Can you please tell me what brand name and model the machine? I need to determine how the needle is normally held in place and how you usually release the needle. I have a couple of ideas but having a little bit better picture of the needle holder will help me provide you the best solution. Thanks
Jan 04, 2008 | White Sewing 2037 Mechanical Sewing...
16 people viewed this question
k24674
jasbo
jasbo
