Question about Kenmore 43042 Front Load Washer
I have a Kenmore Front load washer (model 417.43042 200) and stacked Kenmore electric dryer (model 417.83042 201). The washer is making loud noise on spinning. I need to replace the washer. I ordered Kenmore 40412 from sears but the delivery guys said the existing dryer will not fit on top of this. I would like to use my existing dryer (Kenmore 83042) with any washer that I can stack on. Can you please let me know which washers are compatible with this dryer.
  • rjhanji Dec 29, 2010
    The equivalent part for Kenmore 43042 is Frigidare FTF530FS
3 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Can I stack my Kenmore washer (front loader) and dryer?
They can be stacked, but you will have to purchase a special kit to do it. Sears should be able to order the kit for you. Without the kit, when the washer goes into spin, the dryer will fall off (not good at all). Good Luck!!! Jim
Posted on Sep 09, 2007
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Washer stinks terribly and has become so loud you can hardly be in the room when it is on.
Check out this tip I wrote about the noise and vibration thatfront load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 18, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
My Kenmore 417.94812301 stacked washer/dryer makes a horrible squeaking noise when the dryer is on. It is not overloaded.
What you need to due is take front off dryer and either you're blower is making the noise, or the idler pulley and even the support wheels could be as well
Feb 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Dryer makes loud noise
Probably a bad set of glides.
ea82af1.jpgor worse.Check out my BLOG on this
May 19, 2009 | Dryers
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Dryer stopped working
    The dryers drive belt most likely broke. it must be replaced with a new one.
    Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
    Very loud after stacking.
    I assume you used the kit for stacking and removing the top of the washer and installing the plates?
    You might need some sticky rubber pads to stop metal to metal contact and some duct tape around the vent exiting the dryer where it meets its back panel. This is common, you could go specific or browse ace hardware and find a compatible source.
    Sep 10, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore 43042 Front Load Washer Logo
    79 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
