Question about Kenmore Sewing Machines
I can't get the bobbin winding to work. Am I missing something?
    Genius:
  • 1,788 Answers
Do you have your manual? I don't know what model you have, do you have a clutch on the handwheel that has to be pulled out to disengage the needle shaft? Do you have the bobbin pushed to the right ? Do you have the thread running the right way? If, you have checked all that, take the machine to Sears and ask a salesman for assistance. And it is free. They usually are pretty good in the sewing machine department because they never know if you want to upgrade or not.
Posted on Dec 29, 2010
Is this Model 4617 missing the bobbin threading mechanism?
Can't tell from the photo. Perhaps this will help:
Winding Singer Sewing Machine Bobbin
For ~$30, you can purchase a standalone bobbin winder from JoAnn's, Hancock's or even Amazon.com. It will allow you to wind your bobbins even if your machine is missing the appropriate parts. (Also saves wear and tear on your machine.)
Dec 31, 2015 | Sewing Machines
When I wind a bobbin, it makes a screeching noise and the needle goes up and down. What step am I missing ?
On the right side is a big wheel and in the middle a smaller one. You need to unlock the smaller wheel so that the needle mechanism does not run when re-winding a bobbin. You need to use both hands to do it. Hold the bigger wheel and then loosen the inner wheel anti clock wise. Once you have finished loading your bobbin you need to tighten the inner wheel again for the machine to be fully functional again.
Jan 12, 2014 | Singer 7436 - INGENUITY
After I "undid" winding my bobbin, the electronic display still showed the symbol for winding bobbin and the machine will only sew straight. None of the other buttons like back stitch or change stitches...
are you sure you've moved the bobbin winding mechanism back to the right spot? if its still pushed over against the bobbin spool holder it may be stopping the normal functions from working. If that isn't the problem then it may be something for the tech at the Elna dealers.
Sep 10, 2013 | Elna Sewing Machines
Winding bobbin problem Brother NX200
the machine should be checked to see if there is something wrong with the bobbin spindle..
May 16, 2013 | Brother Sewing Machines
Bobbins wind unevenly- tension issues
Sounds like it is actually the tension on the bobbin winder. Make sure that the thread is following the correct path to the bobbin. Other than getting it repaired, a stand-alone bobbin winder (avlb @ JoAnn's or online) for ~$30 would work. One brand is called the Sidewinder. Verify that your bobbins will work on it because some Singer bobbins will not. It's a nice accessory to have because it saves wear 'n tear on your machine plus you can wind bobbins without unthreading the machine.
FWIW, it is usually better to wind bobbins at a slower speed. Higher speed will tend to make the bobbin jump around and the thread to pop off. In addition, higher speed will tend to stretch the thread going onto the bobbin. The thread will not relax until unwound from the bobbin and stitched into your garment. It may cause the fabric to pucker as the thread relaxes. Slower is better!
Apr 15, 2017 | Sewing Machines
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
Problems winding bobbins on my singer 4622 sewing machine
I have two possible solutions:
1. you have the wrong bobbin and it doesn't grip the winder.
2. the small spring on the winder spindle is missing or bent, it is what applies pressure to the bobbin for winding.
good luck!
Jan 19, 2009 | Sewing Machines
Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Dec 23, 2007 | Sewing Machines
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
