Question about Pentair Heater Thermistor Probe 471566
How to replace hi limit switch on pentair minimax nt 471587 , 471694 pool heater
    Top Expert:
  • Pentair Master
  • 8,488 Answers
Either fusible link down front of burn rack or mounted to header
Posted on Nov 16, 2017
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
  • 139 Answers
SOURCE: I have a Pentair Minimax NT heater. The heater
sounds like a flame sensor
Posted on Jun 20, 2009
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
john224
  • 1378 Answers
SOURCE: new ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
SOURCE: Pentair minimax pool heater (1 year old)
Board problem? Did you fix the problem?
Posted on Oct 19, 2009
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
I have a pentair minimax nt and the heater works fine but it turns of automatically around 92 deg. Any ideas , is it the hi 115deg. or hi 150 deg sensor?
I would most likely suspect the temp sensor rather than a Hi-Limit switch. In other words the temp sensor is thinking the water is hotter than it is and sending the wrong signal. Actually it sends nothing, the resistance changes as the water gets hotter and the main control board turns the heater on and off based on this resistance reading.
Aug 31, 2011 | Pentair Minimax NT Heater
When wiring a high limits switch (#471694) on the outlet side of the manifold, which side does the red wire go to?
The wires will go on ether side of the limit switches, so it won't matter wich way you wire it.
Aug 14, 2011 | Pentair Minimax NT Heater
Miimax NT heater. I get a HI error code????
hi limits check gas pressure and burn tubes
Aug 05, 2010 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
I have a minimax nt h lmt light on
You may have a dirty filter, not enough water flow. You may have a bad flo-control valve in the front header. Does the unit cycle? If not the hi limit may be faulty, check for 24vac accross the terminals.
Mar 05, 2010 | Pentair Minimax NT Heater
Pentair pool heater reads HI
thermister needs to be replaced. follow small yellow wires off control board to front header and thats where the thermister goes
Jun 21, 2009 | Pentair Minimax NT Heater
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Heater Thermistor Probe 471566 Logo
371 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
