The 'r' key on my laptop is not working, I have taken off the key and tried pressing it like that but it still does not work! Help is this fixable!?
    Novelist:
  • 121 Answers
It sounds like the keyboard is bad. There are 2 solutions for this:
1.) If you feel comfortable, you can replace the keyboard yourself. Alot of times a good source to find a replacement part at a decent price is Ebay. Alot of people part out computers so you could probably purchase a replacement keyboard for fairly cheap. The keyboard is connected to the motherboard by a ribon cable. The keyboard can usually be accessed by removing the top cover on the laptop near the monitor. After you do this there are usually 3 screws that hold it in place. Once removed you can then change the keyboard. Also remember to make sure you have the laptop removed from the charger and have the battery removed while doing this.
2.) If you do not feel comfortable doing it yourself you can take it to a computer repair shop. Places like Bestbuy, or Circuit City can also perform this service in their computer repair department.
Keep me posted and if you have any more questions let me know. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jul 07, 2008
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Acer TravelMate 2480 Notebook
Acer keyboard issue
Check the "Num Lock" key. Press it once and see if it fixes everything.
May 13, 2010 | Acer TravelMate 5602WSMi Notebook
Space bar dosnt work unless Ireally press hard is this fixable.Toshiba Laptop
its a fail on the keyboard, you can get just the key on ebay check your model number and ebay it, is easy to replace and cheap
Fosg2000, Rate me please
Apr 26, 2010 | Toshiba Satellite A105 Notebook
Sony laptop is in hibernation mode and i cant get it to respond
Press-and-hold the ON/OFF key, until the computer turns itself off. Then, turn it on.
Jan 13, 2010 | Computers & Internet
Keys on the keyboard do not spell the words correctly
First of all check the keys carefully to see that no key is depressed(especially Function and Toggle keys) ok. Drag your pc to Safe Mode by pressing F8 key before it boots to Windows. Allow to stabilize on the desktop and try the keys again. If it doesn't work properly here, then I'm afraid it has to be taken to the specialist. Good luck.
Jun 10, 2009 | Dell Latitude E5500 Laptop
Hello, My Harddisk is 6months old seagate.It was working fine b4 4-5hrs and now i turned on my computer it says No Bootable Device Detected -- Insert boot disk Press any key.My HDD is also not...
Seems like the harddisk is broken, and it's not really fixable... The good news, however, is that after 6 months the warranty should still be acxtive, so you can send it back to Seagate and get a new one. I hope this answers your question, Yannick.
Jun 09, 2009 | Toshiba A75-S125 Satellite Notebook
My lenovo keypad problem still not solved.When I press the key where two virtual keys are taken?For example when I press 'O' '6' are taken.My laptop manufacturer is LEnovo and model number Lenovo Notebook...
It seems that your Num key is active.So when you press any character then No are display .
To resolve this just keep on pressing the Fn key which normally left hand side of ctrl key ,Hold that key and then press the Num lock which normally togle with Delete key .
Solution :- Keep pressing Fn key + press Delete Key .Problem will solve
Mar 28, 2009 | Computers & Internet
SCREEN NOT WORKING
If the screen is blank then you probably switched to an external screen,to switch to a tv
No worries
what you need to do is press the function key and the key with the picture of a mini screen / oval and circle
it will pull you back to your main screen: back to normal.
hope it helps
Dec 14, 2008 | Dell Latitude D600 Notebook
Getting a new lamp
NO replacing the Cold Fusion lamp is NOT EASY if your are not experienced with these do not try it . YES your laptop is very much FIXABLE . When you see the POST PROCESS on your screen then you press Fn key at the bottom left hand corner keep it depressed and then press the function key with the computer icon 2 times - first time switches display to external monitor only , second time to both LCD and External monitor. Actually for LCD screen to glow a small thin fluroscent lamp is used which requires a high voltage of about 150-200volts that is generated by this so called screen card - the correct name Invertor PCB or board.
May 13, 2008 | IBM ThinkPad G40 2388 Notebook
Keyboarb
hi, its a very common issue, the keyboard itself needs to be taken care off,try removing it and clean the contacts/connectors, check if any key is getting stuck? let me know
Dec 03, 2007 | Panasonic Toughbook 51 Notebook
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
