Question about Samsung SGH-A877 Impression Cell Phone
My Samsung Impression's touch screen was on but not working--I got a new flex cable and put in it and now the screen doesn't come on at all. What did I do wrong or did I need another part? Thanks Debbie
    President:
  • 1,812 Answers
Hello ,
Go to there website >support >mobile >
http://www.lg.com/in/support/mc-support/mobile-phone-support.jsp
Download >detals guide>Download lg support tool to PC>install in conputer> and download or update through following software.
and reinstall the software.
Or you can go local technician who can update the driver or re install the driver.
If the problem is same
Please change the LCD
http://cgi.ebay.com/New-LCD-Screen-AT-T-Samsung-Impression-SGH-A877-USA-/280496164011?pt=PDA_Accessories&hash=item414edfccab
It will be better to change by your local technician.
REGARD'S
Shibuda
Posted on Dec 29, 2010
Touch screen won't work
Trying to remove the battery sometimes resets any issues. If it's not under warranty one can repair it with the use of micro precision screwdriver kit you can get at the dollar general for about 4 dollars. First I would disassemble it, and try reseating the flex cable that attaches the LCD screen to the main board. There is a plastic lock that holds the cable in, so make sure to lift that up before gently pulling the flex cable out. If pulling it out and putting it back in doesn't make a difference I would look at replacing the flex cable, and lastly the LCD panel. Because you didn't mention anything about cracks, water, or any other LCD damage, my opinion leans towards the flex cable shorting out.
Dec 06, 2011 | Samsung SGH-S5230 Cell Phone
I have Samsung SGH-A877. It's touch screen works when slide is off and if i open it's slide then touch screen does not work. Please tell me the solution.
Hi
this may have occured due to bad flex cable(that goes from main board to the lcd).Try changing your flex cable that might help.
thanks
Oct 17, 2011 | Samsung SGH-A877 Impression Cell Phone
Samsung Impression touch screen not working, so am unable to retrieve contacts, photos, etc. AT&T said they couldn't help.
Hello
What you need to do is to calibrate your screen.
There is a code to do that,type in the code using the keyboard and use the keyboard "enter key" when done typing. A screen message will come up briefly. Something about processing and that the phone will shut off and restart. After the restart the touch screen should work again.
code: *2767*3855#
If problem persists,you should replace the flex cable and digitizer screen.This should solve the problem
Dec 13, 2010 | Samsung SGH-A877 Impression Cell Phone
What is the procedure to replace an LCD screen on a Samsung Impression cell phone?
Chances are its not your screen. If the touch screen is not working replace your flex ribbon. Just fixed mine.. Follow link..http://www.youtube.com/watch?v=pOH-Fl3jlj4
Oct 15, 2010 | Samsung SGH-A877 Impression Cell Phone
IM RAMU FM ANDHRAPRADESH INDIA.SGH-A877 SAMSUNG IMPRESSION MOBILE FPCB FLEX CABLE TOUCH SCREEN AND LCD DISPLAY WARE THOSE PARTS AVAILABLE IN INDIA .
Contact nearest Samsung Customer Care Service and ask them to provide these items to you. they can arrange it from any part of the country (if available in the country) and from any other country. But they will charge according to the solution available with them
Aug 30, 2010 | Samsung SGH-A877 Impression Cell Phone
I have the Samsung SGH-A877 Impression Cell Phone, and the touch screen isn't working anymore but the buttons outside and around it are. How can I fix my problem?
The reason your phones touch screen is not working is simply because there is a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flex of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flex that runs through the screen to the panel, carefully detach the flex from the panel,
9. unscrew the screen of the phone, remove the flex connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care
Aug 22, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung a877 impression touch screen not working
Replace flex cable.It will back the touch screen into normal operations. Flex cost is around $10.
Jul 19, 2010 | Samsung SGH-A877 Impression Cell Phone
My Samsung S8300 touch screen
Touch screen suddenly not working for my samsung s8300.
keypad working but i can't call.
Jun 23, 2010 | Samsung S8300 Ultra Touch platinium-red...
The touch screen no longer works and the screen goes blank
two things probably 1 the "flex" cable connecting the phone's lcd unit to the main board is broken or ripped or even slightly twisted more than it shud have been or 2 the lcd unit as whole is bad with a minor problem(inclusive of problems to connector joints)
what u cud do at this point is send it a service center... unless u want to open the device which i would say is a pure risk u d be taking... claim any warranty if needs be...
for diy enthusiasts:http://www.yallstore.com/att-samsung-impression-sgha877-display-lcd-screen-tools-p-36788.html this would be the product u r looking for
Jun 15, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung impression has a qwerty slider. one day the screen started to malfunction until it stays blank and nothing on the screen. when slide back and forth, you see a bit of what's in the screen.
The flex cable of your phone is damaged. Send the Phone to Samsung for repair or go to a local repair shop to have the flex cable replaced.
reminder: Samsung does not offer loaner phones or replacement phones.
Hope that'll help you..
Happy Holidays...
**please rate my post**
Dec 17, 2009 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH-A877 Impression Cell Phone Logo
1,184 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
