Question about Whirlpool Washing Machines
I have a Whirlpool top load washer, lxr6232e00. Agitator works, fills and drains correctly, but will not spin. I tilted it back a bit and when in spin mode the motor is turning and the bottom part of the clutch is spinning (the part you can see fromn underneath), but inside the drum is not turning. I took the motor and shaft out to look at the clutch, can't see anything wrong with the clutch (don't really know what to look for) but I figure it has to be the clutch. Am I correct?
  • 135 Answers
SOURCE: upper portion of Whirlpool agitator not turning
Here's a diagram showing the agitator to help you replace it. You can see the other parts here.
Posted on Jan 07, 2008
  • 71 Answers
SOURCE: agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Posted on Dec 25, 2008
mastatech
  • 478 Answers
SOURCE: agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Posted on Mar 13, 2009
SOURCE: Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Posted on Apr 16, 2009
Healeyman
  • 1198 Answers
SOURCE: drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
Posted on May 09, 2009
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washing machine spins but does not aggitate what do i need to do?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Agitator only turns clockwise (Whirlpool top load)
Mar 12, 2009 | Whirlpool LSB6200KQ Top Load Washer
Agitator won't turn and tub won't spin
Dec 25, 2008 | Whirlpool Washing Machines
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Spin and agitator not working
VERY POSSIBLY THE MOTOR/GEARBOX COUPLING HAS BROKEN. NEEDS TO BE REPLACED. SWITCH WASHER OFF THEN TILT WASHER 60 DEGREES BACKWARDS AND CHECK COUPLING. THERE IS A KIT WHICH CAN BE BOUGHT. DEFINATELY A D.I.Y. REPAIR.
Aug 17, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal De
