Question about Danby Dryers
How do you replace the drive belt on a Danby SCD 5505W dryer?
Here are the Danby instructions:
INSTRUCTIONS TO CHANGE DRYER BELT DCD5505W-1
REMOVE THE SCREWS ACROSS THE BOTTOM OF THE FRONT THAT GO FROM BOTTOM UP
REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF.
REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT
REMOVE THE FRONT SCREW FROM THE CENTER BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP
REMOVE THE 2 SCREWS ON EACH SIDE AT THE TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED
REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT
REMOVE THE 2 SCREWS ON EACH SIDE OF THE INNER BULKHEAD PANEL AND REMOVE THE PANEL
AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND MOTOR MOUNTS
THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Posted on Nov 16, 2008
Danby dryer dcd5505w-1
You probably have a broken drive belt.
Feb 17, 2013 | Danby Dryers
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
How replace belt danby electric dryer dcd5505w
Remove the retaining screws off from the front panel. Remove the two wires connected to the door switch(the wires can go back on either way).Pull the front panel away from the drum. Look down to the bottom right corner facing the front of the unit and locate the tensioner and drive pulleys. If the old belt is still intact(which is usually not the case) remember the routing order of the belt. Slide the new belt onto the drum keeping in mind which side goes to the drum. The ribbed side should face outward.Next you want to curl the belt over the tensioner(providing the tensioner is still in it's slot) and then over the drive pulley. Replace the front panel and the door switch wires. You're good to go. Thank you, Dana
Oct 06, 2009 | Danby DCD5505W Electric Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Where can I buy the dryer belt?
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Sep 29, 2008 | Danby DCD5505W Electric Dryer
Danby dcd5505 dryer belt replacing
remove the bottom and/or front panel. The top panel will need to come off as well. The belt should go around the drum that holds the clothes and a drive wheel at the bottom of the machine.
Jul 03, 2008 | Dryers
Danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Part Number DB-6060532 available at marcone.com
Mar 18, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
205 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
