Question about Frigidaire GLEQ2152ES Electric Dryer
What power is needed for gleq2152es - Frigidaire GLEQ2152ES Electric Dryer
  • Frigidaire Master
  • 7,482 Answers
Your is 220 volts...some can be wired for 110 volts
Posted on Dec 29, 2010
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
What is a hard reset?
Good Morning Friend,
I understand you want to know what a hard reset is on your Frigidaire dryer, model# GLEQ2152ES. A hard reset involves you either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. You will turn the power back on and see if whatever issue has been resolved. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Not heating up?
I understand that your Frigidaire dryer, model# GLEQ2152ES, is not heating up. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once the time has passed, restore power. Start your dryer on any cycle and let it run. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire GLEQ2152ES Electric Dryer
How to switch the door on model gleq2152es
Good Afternoon Bob, this is Z. Thank you for allowing me to assist you!
I show that the doors on your Frigidaire dryer (GLEQ2152ES) cannot be reverse/switch. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
May 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My GLEQ2152E won't run
Hi cory_pettifo - Try reprogramming the dryer by flipping the household circuit breaker off or by unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then typically this is something that a professional would need to accurately diagnosis. Unit could possibly have a faulty power cord, house wiring, faulty control board, thermal limiter or door switch.
Feb 07, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Wired outlet incorrectly and breaker tripped. dryer will not come on. there is power in the outlet. no beeps or anything, completely dead. model number gleq2152es
hello if it striped the breaker theres a dead short somewhere in the dryer something on the power supply board could have shorted to ground check the glass fuse on the power board of the dryer if blown make sure you use the same rated fuse also check the capaitor next to the motor these can go short circuit hope it helps
regards
shaun
Jan 04, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer twisting and catching clothes
there is a front felt piece that if it is warren out will catch your cloths and rip them. you need to replace that front felt.
this part might be the cause of the felt getting damaged. http://www.partselect.com/PartDetail.aspx?Inventory=419088&SourceCode=5&ModelNum=gleq2152es
this is your felt http://www.partselect.com/PartDetail.aspx?Inventory=975866&SourceCode=5&ModelNum=gleq2152es
Oct 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
