Question about Microwave Ovens
When switched to brew mode, the GFI tripped. When reset it just keeps tripping. Also smelled like burn wire. Is the motor burned out? Can it be replaced by me, where do I get parts and instructions, and how much would that cost versus having it repaired. Are there local repair shops near Milford, NH.
  • johnb477 Dec 29, 2010
    The problem is not associated with a microwave. It is a Francis Francis model X1 Espresso machine. Can you help with this?
    My problem was categorized as a Microwave. The question/problem relates to an espresso maker, made by francis francis, model X1. The unit was used serveral times and when it was turned back on it tripped the GIF and it smelled like burnt electrical. Can parts be purchased and replaced without a repair tech.?
  • 10,319 Answers
It all depends on the model of this microwave oven. If you paid $175 or less for it purchase a new one instead. Repairs will cost about that much or more in your area
Posted on Dec 29, 2010
Started tripping the GFI outlet. Outley appears to functioning correctly after re-set, but the microwave keeps tripping it when I plug it back in
HI Joe
Couple of things to consider here.
  1. There may be a GFI plug there at the microwave, but it can get tripped by current leakage on other parts of the circuit. If there are other things plugged into the circuit (every outlet that's on the same panel breaker), it's possible any of them could be causing the tripping. Unplug anything else on the circuit, then plug things back in one by one to see if there's something that may make it pop.
  2. The reset switch in a GFI plug is mechanical. If it's been tripped a few times, it may be worn or not fully reset. Electrical guides usually suggest testing / resetting GFI plugs monthly, both to make sure they work, and also to cycle the mechanical switch. If dust, toaster crumbs, or other stuff might have gotten into the mechanism, it might not be mechanically resetting properly. Try test/reset/test/reset a few times and see if any of the clicks start feeling more distinct.
  3. The trip can be legit. Hopefully not the microwave, but if there is a short in the line somewhere, you really want to track it down before it causes a fire. In some cases, even heavy dust on/in outlets can cause pseudo-shorts with some current trickling to ground. GFI switches will usually trigger with less than 5 mA of current drop, so it doesn't take much. Blow out the receptacle with canned air.
The switch or it's connections may be bad. Unplug the microwave and (no cutting corners here), turn off the breaker to the plug. Undo the faceplate and mounting screws and pull the plug away from the wall. Check that the wire connections to the plug are tight, and that the wire nuts connecting the plug to the wall lines are also firm and tight. Tighten if necessary. If you're still getting trouble after trying this all, Consider replacing the outlet and seeing if that helps.
Hoping this helps!
D
Dec 07, 2015 | In Microwave Ovens
Microwave clock and panel was lit in am wasn't used but in evening when went to use it isn't lit and won't work at all
Hello Anonymous
At the risk of starting with the very basics, when you say that the clock and panel aren't lit and wont' work at all, the first place to look is the wall power. You may be missing power from the wall because:
  1. The microwave isn't plugged in. Someone may have yanked a plug to plug in a mixer, phone charger, thanksgiving animated ornament, or what have you. Trace the cord back and make sure it's plugged in.
  2. Make sure the outlet has power. Take some plug-in-able item and plug to the outlet and see if it can turn on. If not:
  1. A number of kitchen outlets may have GFI switches, especially if they are anywhere near sinks. The GFI may have been tripped. There should be a reset switch in the middle of the plug. See if it's tripped, and reset if necessary.
  2. The breaker may have been tripped. Most kitchen circuits are wired to 20Amp breakers. If this is elsewhere in the house, like in an entertainment room or such, it is likely a 15 Amp outlet. Microwaves can draw a fair amount of power. Someone using another kitchen appliance, hair dryer, or what have you, on the same circuit, may have tripped the breaker. Newer code may specify an AFI or GFI breaker for kitchen outlets. In that case, a fault with something else on the circuit may have tripped the breaker. If that is the case, and it trips again, talk to an electrician. You don't want a fault like that undiagnosed.
    3) You may also want to try plugging the microwave into another outlet, even if the normal outlet seems OK
    If there's wall power and a good plug-in, then you work back to the microwave itself. A number will have fuses. Also, there may be interlocks that kick in if, for instance, the carousel rotation is impeded - that can mean something on the carousel is hitting a wall, which can risk tipping something over and spilling, or risk mucking up the reduction gears for the carousel axle if it keeps pushing.
    At that point, looking for specifics on your microwave model will be needed. You may also try the Microsoft Support approach - i.e unplug it for 5 minutes, then plug it back in and see if it works.
    Hoping this helps, Good Luck!
Nov 18, 2015 | In Microwave Ovens
Tripping GFI
proceed using the common sense. You must open the microwaves for to see what happen, the coffee produce bad contacts, and reaction from component like short, etc. However the following. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 17, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Our GE dishwasher has been working fine for years. Now it is tripping the braker? all wiring is good right to the dishwasher. We did smell burnt wires but it went away.?????
Your dishwasher may be damaged beyond repair. When I installed the dishwasher in my home I found that there is a surprising number of wires bundled under the dishwasher. If you are skilled in that field you can pull the dishwasher out and try to repair the damaged wiring under the machine. However once you've smelled burned wiring it means that there are potentially significant problems in there. You aren't smelling the burnt wires anymore because the damage is so great it's just tripping the breaker. If you continue to try and force the machine to work in this situation you may end up with a fire and further damage.
Please be careful.
Apr 06, 2011 | Microwave Ovens
Ge spacemaker microwave, new, keeps tripping the GFI but keeps running
The first thing you need to check is the GFI--when it trips, it definitely should shut off power to the circuit. It may be wired incorrectly, or is faulty. There should be a 20 amp breaker and wiring to the oven.It is also much better is the oven is the only appliance on this circuit. Hope this helps!
May 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Comes on and kicks breaker smells like something is burning
if you smell burning then i would say the transformer is burning and if will trip breaker . some times the mag has failed causing over load to trans and both will have to be replaced. this is a big buck repair . you may want to replace ..
Jan 04, 2010 | Hotpoint RVM1435 Microwave Oven
Danby Microwave, stopped working, no power, would it be a fuse?
check the gfi it might have tripped that or a fuse if its neither its dead I work in a kitchen and burned up plenty of micros over the last 13 yrs
Dec 02, 2009 | Danby DMW1153 Microwave Oven
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
