Question about Moyer Diebel 401HT Dishwasher
The temp of the water is 200 degrees.How do I turn it down to 180
    Problem Solver:
  • 40 Answers
If the temperature was ok before, and no one has adjusted the thermostat, then that is an indication of a thermostat that needs to be replaced.
Posted on Jan 11, 2012
Water on/off is in the wrong position after changing the moen cartridge in my shower
Put your cartridge back the way it was originally. By rotating 180 you reverse the hot and cold. Leave the handle and plastic adapter off. Turn on your water supply and turn valve with the plastic adapter until the water is shut off. Remove the adapter and install it with the set screw for handle facing down. Put your handle back on and that should take care of problem. (I did the exact same thing as you today....small world)
Feb 16, 2013 | Moen Posi-Temp Single HandleTub And Shower...
Bunn Dual only heating to 180-185F
Is there scale buildup on the heating element? Can you check the voltage of heating elements. They should read in the 208v range. If all checks out then I would change out the thermostat.
Jan 13, 2013 | Bunn DualĀ® (20900.0011)
Thermostadt was stuck open replaced thermostadt now it runs just a little hot
Yes, try a 180 thermostat, with a 195 the fans will not turn on until about 210.
Oct 05, 2012 | 2003 Chevrolet TrailBlazer
What the normal temperature operating range indicated on the temp gauge?
195 degrees is the typical high end on the thermostat (when the thermostat opens), so the temp gauge should read a max of 195 degrees, give or take a few degrees. Some people replace their thermostat with a lower temp one, such as a 180 degree one. Then the gauge will read lower (approx 180 degree max). So the range is typically from cold at start to just under 200 degrees.
Jul 31, 2009 | 1995 Oldsmobile 88
97 pontiac firbird, 3.8 v6 , 140k miles auto.
Front of the engine...looking at the motor...to the driver's side of the alernator...looks like a spark plug almost...has a wire connector going to it. Trying to post the pic...but at least this is a good description.
Apr 05, 2009 | 1997 Pontiac Firebird
Water turns from hot to cold
The valve stem has been turned 180 degrees allowing the ports to be on the side opposite the display on the chrome trim. This is a simple solution. Cut the water supply off to the valve, and bleed the pressure off the valve, remove the handle,remove the chrome extension tube behind the handle, pull the brass clip out of it's slot, spint the valve 180 degrees and reassemble. If you have an issue gaing access to the valve cartridge to turn it 180 degrees put the handle back on and carefully pull the cartridge out and turn it 180 and reinsert. This will resove your issue so that the hot is on the left and the cold is on the right. There is one other possibility and that is that the supply lines were reversed when the shower was roughed in. Either way the 180 tiurn will fix the issue. Thanks fo using Fix Ya.
Mar 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
I have a Honeywell L7224U1002 aquastat and I am unsure how to turn the temperature down. The water is 180 degrees.
I fixed it by holding in the 3 puch buttons for 3 seconds and then I was able to lower the temp by using the up and down buttons.
Jul 23, 2008 | Honeywell Heating & Cooling
Dishwashers Logo
134 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
