Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How to in install the speakers to it - Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
  • Behringer Master
  • 5,603 Answers
You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
Posted on Dec 29, 2010
  • 30 Answers
Not sure on this one but most mixers are designed for line in/out and not for speakers. It would require an external amplifier.
Casio CTK-691 - can you switch the speakers on when headphones are plugged in?
No, the switching is done by the headphone jack. However if you replace the headphone jack itself ou can install one that makes them both on at the same time but then you couldn't switch the speakers off. Or you can wire a switch into the circuit to do it.
Sep 28, 2016 | Casio Music
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
Loud Speakers only have 1/4 inch inputs
Get the Speakons to 1/4" cables. If you're concerned about grounding, make sure the amp is turned off before plugging or unplugging the speakers.
May 02, 2017 | Music
My Behringer Ultrabass BX600 has a very loud, constant hum. I tried a new power cord, and speaker along with checking the internal parts for a burn spot and tight fit to no avail.
It is likely the power amp chip has shorted. This puts the unregulated dc into the speaker and you will hear the hum. DO NOT operate this way as you can burn up the speaker. You will find that the LM3886 chip on the heatsink has failed. They are about $7.30 from Digikey. They come in two lead bent versions. Make sure to get the correct version and use heat sink grease wheen installing.
May 26, 2011 | Behringer Bx4500h Ultrabass 450w Bass...
I need sound please
Make sure to plug it in before you start up the application. Make sure you restarted your computer after installing device.
Did you check system preferences to see the output settings?
I have mine set to output as headphones and have some external speakers in them. If I unplug them the computers speakers turn right on automatically.
Mar 03, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I want to mount an extension speaker jack to my Fender Frontman 212. It will involve putting two or three small metal screws into the metal wall which surrounds all the hidden electronics. I need to know...
You will have to disconnect one of the existing speakers, as adding another speaker in parallel as an extension would go below the minimum design impedance of the amplifiers.
You would need to wire a jack that has a switch so when you plug in the extension it disconnect one of the speakers.
Some amplifiers are designed to use an extension, however ones with two speakers are usually not designed to allow this.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Repair a Mackie SRM 450 Speaker The Speaker is making a crackling sound while playing. The sound keeps cracking up.
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Jul 20, 2009 | Music
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Crate PA6FX
if they are square cement power resistors they are probably 3-5 watt 300-500 ohm .... are there colored stripes on the resistors? those are probably grounding resistors, they usually are installed too close to the board, get real hot a bunch of times and then crack the solder welds. when you replace them bring up the height and make space under the resistor to keep it off of the board and put a little drop of silcone underneath to hold them in place.
Mar 29, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
294 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
