Question about Sharp UX B700 Plain Paper Inkjet Fax
Sharp fax printing problem
It can print a Help List just fine, but will not copy anything. All I get is a page full of horizontal lines. Thanks
  • kireeti Sep 25, 2008
    faxing is fine but dosent copy when i press the copy button
    Genius:
  • 2,120 Answers
Curfman.....your scanner has gone bad
kireeti....open the document feeder and check for obstructions or a switch actuator stuck down.
Posted on Oct 13, 2008
We received a cople of faxes from different sources. There are lines down all the pages except the top (there is readable text there) and the lines are from the letters (like they have been stretched) like...
That sounds exactly like the sending fax is document is stalling, so a single line across the page gets sent for a few seconds. You can easily check your own machine's scan and print quality by putting anything in the doc feeder and copying it.
To test the print section alone, use the menus (or I think your model has a separate Report button) to print out the Help list.
It's possible that both your sending correspondents have slick, hard document feeder rollers, but you'd think they would have heard complaints from others. I can't think of anything at your end that would stretch out your prints, and there's no Bulletin about it on Brother's service website.
On the off chance you have a glitch in your machine's memory fouling it up, you can clear it out. This page has instructions for clearing out only the image memory (91) or all of it (01). It may or may not help, but only takes a couple of minutes to try.
Oct 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
May 29, 2009 | Brother IntelliFAX 4100 Laser Fax
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
