Question about Linksys Wireless-G WRT54G Router
Lose Connections over and over...
Hi, I installed the Linksys Wireless-G WRT54G two months ago and have been to the help desk twice but still having connections problems. I have 3 computers (1 MAC, 2 laptops) and VOIP hooked up to the router. I use this for my home office and the other computers are rarely used and do not seem to have the connection lost problem. I run Windows XP, use VOIP (Vonage), VPN for my office and run many netmeetings and Instant Messaging all at the same time. I have tried both hardwire and wireless connections to the router but continue to be dropped. Usually what happens is I will be on the VOIP line, and running all above and then the voice goes silent, no audio, VPN goes down and then internet is dropped before it self boots again on its own. Any ideas of what I need to do? Please help, this is effecting my day at work.
  • bconvery Jul 07, 2008
    I have gone to the applications and gaming tab and not exactly sure how and where to set the specific ports VOIP needs to access the internet. Sorry to bother you again can you advise as to the menu path? Thank
  • coach4ward Jul 07, 2008
    there are no ethernet lights coming on the router - no wirless connection.....help!!
  • 137 Answers
You may need to set specific ports on your router to use the voip. log onto router and go to the applications and gaming tab to set the specific ports voip needs to access Internet.
Posted on Jul 07, 2008
  • nsindian
    nsindian Jul 08, 2008
    you are at the right tab but voip uses different protocols than you can select on that router page(UDP/TCP). Does your voip use a gateway of any kind? Have you set up the router to be a dhcp server? if so, i woiuld statically assign ip addresses to the devices connecting to router and maybe put the voip device on the dmz port.
I have a linksys wireless-g wrt54g v8 router but do not have the installation cd. I have a desk top pc w/ a dsl modem and want to install the router so I can use a laptop in other parts of the house. Do...
Hi leftella, First of all, I would like to ask you few questions. 1.Who is your ISP(Internet service provider) like verizon, Bell, Comcast? 2.How many ports you see at the back of the Modem?like WAN, Ethernet, LAN, DSL, Data? 3.How many ports you see at the back of the Router?like Internet,Ethernet,WAN, LAN? 4.What is the make and model of the laptop with which you want to go wireless?
To setup the router you don't need any CD, just need to connect the Modem to router and router to your computer with hard wire Initially and then after setup, you can go wireless.
Sep 15, 2011 | Linksys Wireless-G WRT54G Router
Hi I have a linksys wireless-G broadband router but I have no instructions to set it up
go to http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G, click on downloads tab and select a Quick Installation Guide.
Sep 27, 2010 | Linksys Wireless-G Broadband Router
Can't connect to wireless
Hi, the first thing i would recommend is going to your linksys router and try turning it off for approximately 10 seconds then restoring it. Routers need refreshing at leasy on a monthly basis and tend to lose connection. Step 2: if that does not work try the following. first click start, then go to control panel, then click network and double click network and internet connections. then click on network connections and right click on the network connection you use and click repair option. The repair option will fix your connection most likely.
Jun 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless connection problems.
click on Start -> Control Panel -> Network Connections -> Wireless Network Connections -> Properties -> In the box in the middle scroll to and click on "Internet Protocol (TCP/IP)" -> Click Properties -> Make sure "Obtain an IP Address Automaticaly" is Ticked -> make sure "obtain dns address automatically" is Ticked. -> ok -> click ok
See if you can connect
Click on Start -> Run -> Type CMD and hit enter.
a command box will open. type in IPCONFIG/ALL
Please copy down the following numbers ---
IP Address
Subnet Mask
Default Gateway
DNS Servers
Please make sure you copy them correctly and post them here.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Hooking up wireless linksys
From ethernet of embarq plug it to the Internet port of Linksys. Your PC should be connected to port 1 of Linksys
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
My laptop is not working
you mean not working wirelessly? please elaborate so we can help.. :-)
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Connection trouble
I purchased linksys WRT54G when I connect the second wiring I
lose my internet. My wireless use to work but since I disconneted it and reconnected the wireless does not work.
Jul 11, 2008 | Linksys Wireless-G WRT54G Router
Need to know how to wire from desk top for lap top, I have router #wrt54g
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3988&lid=7553637401B09
HI
Use this link to get the required information
thank you.
Apr 30, 2008 | Linksys Wireless-G WRT54G Router
Make my existing wireless connection secure
Ginger,
I am back online if you need help. I will be online most of the day tomorrow.
Thanks,
Brad Nelson
Mar 23, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
202 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
