Question about Zebra P120i Thermal Card Printer
I'm printing a double sided card. The back side comes out fine (white with black letters). The front side needs to be completey black with red letters. It keeps coming out blurry. How do I fix that?
  • 20 Answers
The problem is when the printer print red using the YMC colors which are dye-sublimation, it can't perfectly alight to the K-Black resin print. Your best solution would be make the black color slightly lighter which will force the printer to print it using the YMC panels instead of the K-Resin (which is pure black), however using the method the black print will be greyish in color.
The other more complicated way includes printing a full red card, then using the black as an additional image with white space for your red text.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
  • 312 Answers
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
http://www.zebra.com/id/zebra/na/en/index/products/printers/card/p120i.4.tabs.html
Hope this helps,
Best Regards,
Mark
Posted on Dec 29, 2010
1 copy to front and back from computer
umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
May 21, 2014 | Kyocera CS-2550 Black and White Copier
My fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Feb 23, 2012 | Fargo DTC525 ID Card Printer
HOW do I print on both sides of paper automaticly
First, you need to have the HP Automatic Two-sided Printing Accessory (Duplexer) installed on your printer for it to print double side. If you have it installed, depending on your operating system follow the information on this page: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=au&lc=en&dlc=en&product=3760410&tmp_track_link=ot_search#N242
Feb 05, 2011 | HP Officejet Pro 8000 Wireless InkJet...
Printing in black mono only. A portion of the
Common problem is a dirty card, make sure you handle the cards by the edges and not the surface as oil from finger residue will cause a misprint on that part.
This problem can also be caused by improper or too low of a setting for black intensity, where the printer does not apply sufficient heat to transfer the color onto the card.
Also check for a faulty ribbon, if the ribbon is not properly stored or is more than 3 years old, it can also cause this issue.
Nov 12, 2010 | Zebra P330i Thermal Card Printer
I would like to know the wiring conections for the plug-in on the back of a pioneer deh-2000mp cd player. What color goes where? Thanks
All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Apr 06, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Why does my hp 1220c print letters double struck type red/black i
check you cartridge, is it new and genuine, if you have not troubles in cartridge, check the cleannig station
Mar 30, 2010 | HP DeskJet 1220c InkJet Printer
Canon iR2016 PCL5e A4 copies have suddenly started to print out in landscape, regardless of any buttons pressed. This means all copies are coming out portrait shape but only printed across the middle. Any...
Check and make sure the paper setting is on what it thinks it is. In other words, make sure the the paper in the tray is letter and the display says letter, instead of letter-r (letter-r runs the long way from side to side in the tray, and letter runs the long way from front to back in the tray) or any other size. I am not familiar with the set up of the paper trays on that machine, but if you have to program the paper size yourself, make sure it is what it is.
Oct 27, 2009 | Canon iR 2016i Black and White Copier
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Jun 17, 2008 | HP LaserJet 5550 Printer
HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Apr 28, 2008 | HP LaserJet 5000dn Printer
Zebra P120i Thermal Card Printer Logo
293 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
