Question about Home
I have a Pearl Whirlpool tub with a Multi-speed Pump control. When I push the control button, the red light on the control blinks six times and the whirlpool does not start. According to the Owner's manual, the light will blink four times if there is not enough water in the tub. The low water sensor is covered with water but the pump will not start. What might the problem be? Thanks.
SOURCE: whirlpool Duet
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Posted on Feb 03, 2008
funkyjacob
  • 76 Answers
SOURCE: No Picture or sound, red standby light blinks six times
Sorry for how long it is but you should be able to find what is wrong in this guide
If you have any questions please dont hesitate to ask
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on Dec 03, 2008
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
  • 659 Answers
SOURCE: installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Posted on Mar 23, 2009
  • 10865 Answers
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on May 21, 2009
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
Air push button activates the pump when pushed down but pump stops when I let off the button.
It could be a number of things. A faulty hose situation or the switch are most probable. If you have access to the switch area, you can try to do a visual on the hose to make sure it is fastened well. You may get very lucky and find the hose (through time) has moused its way loose.
If you have a meter, you can go much further.
Apr 15, 2011 | Whirlpool Pearl CS P6 True with Air Push...
Whirlpool tub pump only runs in slow speed
give aquaglass a call at 731-632-0911 they will be glad to help you,i worked for them at one time
Feb 14, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Moter does not turn ON
If the tub has an push in off/on button, the problem is the air switch which is attached at the back of the motor in a black box. If the control panel has touch buttons, the problem lies in the control box that controls the pump or the pump itself which might be seized. If you can unplug the pump from the control box, it can be plugged into an outlet to see if the pump works. Unless you are mechanically inclined it would be best to leave this to a pro.
Sep 06, 2009 | Jacuzzi LUMINOSA WHIRLPOOL SINGLE SPEED...
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
The blackberry pearl 8100 turns off by itself and than the red light just blinks 2 times stops and then 3 times and then repeats. it will not turn on unless i connected to the charger.
Hi Will No Problem
1)The red blinking light you have a text message waiting
2) The blank screen is a sleep push the button on the very top left 3)Turn it off and it works And please do let me know
Mar 25, 2009 | RIM BlackBerry Pearl 8100
Home Logo
299 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
