Question about Hayward 116k HeatPro Heat Pump HP3100
What does L5 or LS mean? - Hayward 116k HeatPro Heat Pump HP3100
My treadmill not running after 7 seconds diplay shows L5
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It is common to see this error as and L5 error, but it is actually an LS error. The following information will define this error and give you the possible solutions to fix this issue.
LS Error with No Belt Movement on Landice Series Treadmills
LS Error on Landice L-Series Treadmills with No Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
Corrective Action A) Enter Open Loop Speed mode and set treadmill speed to confirm proper line voltage to pwm board and that the green BELTSW light is lit on the relay board. Replace upper display board or relay board if necessary.
B) Inspect speed control wiring and correct wiring if necessary:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
C) Inspect motor control wiring, checking wires from motor to A+ and A-. Correct wiring if necessary.
D) Inspect motor brushes verifying brushes slide freely, are at least 3/8" long, are curved and have no burns or cracks. Also check the brush springs and verify that the brush copper wire is not burned or broken. Replace both motor brushes if necessary.
E) Inspect motor turns and is not seized up or has a broken shaft. Replace motor if necessary. Also verify at least 90VDC present from the black (A+) wire and white (A-) wire from the pwm board to the drive motor. If voltage is present, replace pwm/relay combo board. If no voltage present, replace drive motor.
Details about LS Error on Landice Series Treadmills with Belt Movement
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
Correct speed control wiring if necessary.
Oct 13, 2015 | Exercise & Fitness
What is l5 error
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
Hi, i have KEB inverter type F4C on my CNC machine... it shows the message L5 (or LS i am not sure about the symbol). The machine showing motor problem and inerter problem. Please advise me on m y ema
LS means Low Speed. The inverter is enabled and is waiting for a command.
Check your speed and direction signals at the inverter to verify if they are active.
Nov 16, 2011 | Inverter KEB COMBIVERT F5
The belt won't move, Err-L5 keeps on coming on what seems to be the problem can u help me Pat Morelli
L5 or LS is short for Low Speed error
It basically means that the speed sensor is not picking up a signal. Unfortunatley its a pretty vague error code and can be caused by several different problems.
First you have to determine wether or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS w/belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good you will need the MCB replaced.
Hope this helps (remember to rate this answer).
Jun 09, 2011 | Bowflex Series 3 Treadmill Msrp 129999
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
Mar 14, 2011 | Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
I have a Landice L8 and the error code L5???
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hayward 116k HeatPro Heat Pump  HP3100 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
