Using the Crosley CR2406A CD Director: 1.) Once an album has been converted to CD player 2.) The finalize button is pressed 3.) The newly made CD is played on another stereo and the CD shows to be a "blank CD."
  • kattebury2 Dec 29, 2010
    Tried to play it on the stereo and the PC and both showed that the disc was blank.
Try using a different brand of CD-R disc. Some CD-R disc's won't work in some stereo's. Look at the bottom of your finalized disc and check to see if it has been written over. If you don't find evidence of lines that have been burned into that blank CD then you will need to check your optical drive on your Crosley to see if has failed.
Posted on Dec 29, 2010
  • 5,603 Answers
Try reading the CD on a PC to see if there is anything on it. If it plays there, your system is probably making a CD with a format that your particular player can't handle... Possibly MP3.
How do i fix the cd holder when it is stuck
The gears usually dry up or get stuck with hair. You need to open the panel and re-grease it.
Jul 22, 2015 | Crosley Radio CR2406A-PA Director CD...
Tip
Region free code for Samsung DVD M105
Code 1:
Switch the player off and on.
Hold the play and stop buttons (for 10 seconds).
Press the Repeat button on your remote control.
Using your remote control enter the code below (note that you must know what Region your player is currently set to in order to know which code is appropriate):
For Region 1 use 2, 9, 3, 3 and 4;
For Region 2 use 3, 8, 7, 6 and 7;
For Region 3 use 5, 6, 7, 3 and 2;
For Region 4 use 7, 6, 8, 8 and 4;
For Region 5 use 5, 3, 8, 1 and 4;
For Region 6 use 2, 4, 4, 6 and 2;
A code should be displayed on the screen indicating the current Region setting of your unit.
Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Open button on your player.
Press the Standby button on your remote control.
Code 2:
Power on.
Press the open/close button, the CD-tray will come out, remove DVD or other CD if present.
Press REPEAT button once.
Enter following numbers: 38767.
Yyou will then see '02' on the TV-Screen.
Press button number: 9.
Press the open/close button.
Power off, then on.
on Mar 07, 2010 | Televison & Video
Tip
Region free code for Samsung DVD M103
Code 1:
Code 2:
Power on.
Power off, then on.
Where can I get a schematic of the power board E315942?
Find somebody from Manila, Philippines and ask them to get you one at Raon. If they don't have it in stock they will make it for you.
Jul 02, 2015 | Crosley Radio CR2406A-PA Director CD...
How can I get my crosley cr2405a out of standby mode?
http://www.manualslib.com/manual/503736/Crosley-Cr2405a.html this is the URL for the manual.
May 07, 2014 | Crosley Director CD Recorder with Cassette...
How do you record a cd from tape on crosley cr2406a
Set the function to "phono" and record it the same way you would an album.
Dec 01, 2010 | Crosley CR248 Turntable
Can i get the power out put of the transformer for a cr2406a
If you need for to replace the transformer, because it has failed, and looking for a replacement, then you need not bother. The reason for this is that makers consider power transformers as safety parts and should be replaced with the same part. Or least one approved by Crosley.
Feb 24, 2010 | Crosley 4-in-1 Entertainer CD Shelf System
Compre un crosley cr2406a en miami y el librito de informacion para manejarlo no lo entiendo porque esta en ingles, aparte quiero saber sies compatible para argentina
compre un crosley cr2406a en miami y el librito de informacion para manejarlo no lo entiendo porque esta en ingles, aparte quiero saber sies compatible para ecuador
Jan 21, 2010 | Crosley CR248 Turntable
Ihow to put movies and pictures on the gpx mp3player
Plug in your MP3 Player. Open MY COMPUTER, your MP3 player will show up in the scroll on the left side of the screen. Go into your documents to select an image and simply drag and drop on top of the folder called ALBUMS under the GPX. This will put images into an album on the player.
To See the images once on your MP3 player,
1. Turn on the Player
2. Hold MODE BUTTON
3. press up or down until you select PICTURE
Your images will appear as a list.
I find that .gif images and .jpg images work the best.
Video files must be .AMV formatted to work on this MP3 player. Below is a link to an amazing converter. It’s FREE and will convert your entire file.
http://in.answers.yahoo.com/question/index?qid=20070610062401AAZXp2P
Once you have the video files formatted to .AMV
  1. plug your MP3 player into the computer
  2. Go to MY COMPUTER, you should see a scroll bar on the left.
  3. Find your .AMV VIDEO
  4. Drag file to the Scroll Bar, hold the file over the GPX DEVICE
  5. Two folders will appear under it. Put file into ALBUMS
To then access videos put onto the device. Hold the MODE BUTTON on your MP3 player until you are returned to your menu screen. Scroll to MOVIES and your videos will be there. :D To return to listening to music or looking at Pictures, hold the MODE BUTTON and simply select your desired destination.
Jul 03, 2009 | GPX ML648B MP3 Player
Crosley CR2406A will not record CDs properly.
I had this problem when recording CD-Rs. I switched to CD-RWs and didn't have the problem again.
Feb 18, 2009 | Crosley CR248 Turntable
 Grubhead
Grubhead
