Question about Garden
Cannot undo butterful nut. Does it undo clockwise or anticlockwise?
    Sergeant:
  • 223 Answers
Anticlockwise to unscrew it.
lp
Posted on Dec 29, 2010
How to undo left hand back wheel studs?
With the car on flat and level ground with a wheel chocked, slacken off a little with the wheel wrench anticlockwise. Then jack the car up. You can stand on the wrench if it is a good fit.
If you really mean remove the studs themselves rather than the nuts, there are two ways. Lock two nuts tightly together and undo, or use a stud remover which grips the non-threaded part.
1 4 to 3 4 in Stud Remover Princess Auto
Dec 06, 2016 | Cars & Trucks
Clockwise or anticlockwise to undo blade bolt
On table saws to undo bolt is anticlockwise . Just lock blade against medal, with screw driver threw holes to hold blade tight and turn anticlockwise to losses. Make sure you unplug saw for safety of course . Thanks, Mike
Aug 10, 2011 | Saws
How do I adjust final drive chain
hi place machine on the centre stand, on the chain side of the bike you will see 2 x17mm bolts first undo these, secondly using the special c spanner from the tool kit locate the ecentric splined nut rite behind the sprocket turning this nut clockwise will loosen the chain, anticlockwise will tighten the chain, before adjustment always check the chain condition rotating the whee looking for extreme tightspots the chain should be considered as failed and replaced with a new 1, after tigtening chain re check for tension rotating the wheel and checking tightness all around, when happy retighten the 2 x 17mm nuts, do not overtighten these nuts, good luck easy job
Nov 13, 2010 | 2006 Ducati Multistrada 1000 DS
When removing rear wheel.to undo near side nut.does it undo clockwise or anticlockwise ?
Mine is a standard thread.
Clockwise to tighten, anticlockwise to loosen.
Oct 31, 2010 | Honda VT 125 Shadow Motorcycles
Are the threads on the nut for the crankshaft pulley left or right handed?
Hi they are normal nuts so will undo anticlockwise, but to undo this nut/bolt your going to need to lock the flywheel you can do this by either removing the starter motor and jamming a big screw driver in the teeth of the fly wheel so that it lock on the casing of the gearbox or you can undo an inspection panel on the gearbox to give you access to the fly wheel and then jam it that way other than doing this you would need air tools to undo this nut without jamming the fly wheel
May 22, 2010 | 2000 Nissan Frontier
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
How do I remove the gas cylinder
you anticlockwise to tighten clockwise to undo ,lefthanded thread
Apr 30, 2010 | Ducane F7011013
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Plz rate my solution.
Thabks.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
