Question about Keurig Elite B40 Coffee Maker
We are having issues doing the initial test run, the light stays lit and doesn't flash like the instructions state it should. is this a malfunction?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
lift the handle up and down a couple of time's, if that does not solve the problem, your unit maybe defective..dont worry they will take care of you. You can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 29, 2010
2002 Ford Explorer rebuilt motor starts but won't stay running
Could be any number of thing's an without doing test's we'd only be guessing . Alot of sensor's ,electronic's etc.... Any light's lit on the instrument cluster ,or flashing ? security light etc... Your best bet ,have a qualified technician diagnose the problem .
Dec 26, 2017 | 2002 Ford Explorer
I have a 1996 Yamaha Virago 1100. The rear left turn signal stays on, the right rear flashes fast when turned on and the two front running/signal lights dont come on. What should I do
Hi, Joe before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ViragoTechForum com
ViragoTechForum com
http://service.tanga-moteurs.ro/data/yamaha_virago_535_700_1100.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/1998/lit-11626-10-86_1253.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 20, 2014 | Yamaha Motorcycles
Yamaha tdr indicators dont flash
Hi, Lucyemma2009 before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Indicator doesnt flash it just stays on
http://www.apriliaforum.com/forums/showthread.php?179848-LED-Indicators-Won-t-Flash
http://www.yamaha-motor.com/assets/service/manuals/2007/LIT-11626-20-01_ttr125all_1961.pdf
YAMAHA TDR125 Owner Manual
May 06, 2011 | 2000 Yamaha TDR 125
The warning light for engine malfunction came on thismoning while i was driving and has stayed on the car is driving quite normally, could itbe anything serious andexensive to put right?
If the light was flashing when it came on, then it means your engine is misfiring.
A solid light can mean anything from a loose/faulty gas cap to a transmission issue.
This light comes on when the computer detects a fault of some sort in its diagnostic tests. If it keeps detecting this issue, the light will remain on. If the light turns off, then it has detected that the issue may no longer be present.
In order to find out what the exact reason was for your light, You need to have your car computer scanned to retrieve the code that the computer would have stored when the light triggered. Most garages will do this free of charge. The code will tell you what may have caused the light to initially turn on.
Nov 19, 2009 | 2002 Honda Civic
Check engine light on in 2001 subaru outback - car running okay any ideas what it could be. the vehicle has passed state inspection
Oct 22, 2009 | 2001 Subaru Outback
ENGINE MALFUNCTION LIGHT STAYS ON
A solid light can mean anything.
In order to find out what the exact reason was for your light, You need to have your car computer scanned to retrieve the code that the computer would have stored when the light triggered. Most garages will do this free of charge. The code will tell you what may have caused the light to initially go on
Oct 02, 2009 | 2006 Jeep Grand Cherokee
Gear Position light D4 is always flashing irrespective of gear.
This issue is caused by a transmission fault or malfunction, most likely a shift solenoid in the trans has failed or the trans control module has a problem, the trans can be tested for codes that will show what circuit or component of the trans controls is causing the light to stay blinking, have it tested.
Dec 12, 2008 | 1995 Honda Accord
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Keurig Elite B40 Coffee Maker Logo
51 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
